Thnx for trying?WASN'T NOT HELPFULL THIS LINK???If yess so rate this solution as FIXYA if not let me know i will post another link ok?Thnx for trying?WASN'T NOT HELPFULL THIS LINK???If yess so rate this solution as FIXYA if not let me know i will post another link ok?
You can't post conmments that contain an email address.
Windows 98 does not support Plug n Play Devices. So you have to download appropriate drivers from Microsoft Website. Though Windows 98SE ( Windows 98 Second Edition ) thought to be support USB Mass Storage Drives fairly, these drivers are not pre-installed with OS. You have to download Service packs to install these drivers.
Since Windows 98 have TWO versions, we have to download corresponding service packs .
Installing Windows 98, is you need a start-up disk (floppy disk) first before you can use the Windows 98 cd. The start-up disk will perform the partitioning and formatting of the HD...doing this, you have to boot from floppy drive first---after partitioning and formatting, you have change again the boot sequence to boot from cd then you can start the installation of Windows 98.
I can not find a win 98 driver for your printer on the HP website. DO yu have the instalation disk that was writen for win 98? If not try installing the printer through the control panel. Either printers/fax or through install new hardware.The first being the preference. Some of the win OSs have printr drivers already installed.
If this does not work out, then the printer has no drivr available for that version of windows and you ewither have to upgrade to Xp or use a different printer which has a driver for win 98.
you will need the usb port drivers for windows 98 and the usb drivers for the printer as the earlier windows 98 had'nt the usb drivers included with operating system an as the new motherboards came about with usb ports then a new in 98 was needed to catter for this that's why you have win 98 first edition and win 98 se edition please chech that you have the driuvers installed for both parts to work.
Just follow the following steps:
1) Locate the USB port of your Nokia N72 phone. See Manual if needed.
2) If your mobile phone has a USB Data Cable supplied, connect the end that matches the hub while connect the USB end to your USB port of your PC.
3) If your mobile phone has a CD supplied, this contain the PCSuite software bundled with drivers for your PC operating system.
4) Insert the CD to your CDRom drive.
5) After step 4, you will see a window saying install PCSuite then choose Yes.
6) Choose which operating system. If you use Windows 98, then choose the driver for Windows 98.
7) After installation, reboot/restart tour PC to complete the setup process but never disconnect yet your USB Cables from your mobile phone to PC.
8) Once restarted click on the icon of the PCSuite on your PC, then check if your PC can communicate with your mobile phone and vice versa. To do this click connect via USB if the datas in your mobile phone is seen then connection is correct.
If your problem is USB Driver for Windows 98, i suggest you upgrade your PC operating system to Windows 2000 or Windows XP. Old operating platforms have driver problems when new devices are attached to. But if you choose Windows 98, you will have to browse the internet in search of drivers. Just let me know if you have not found a driver. I'll assist you with this.
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer.
Nikon View 5/6 compatibility:
Windows 98 SE
Windows ME
Windows 2000
Windows XP Home Edition/Professional
Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional.
Cameras that are not supported by Nikon View 5/6
Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras.
Before installation
- Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard.
- You have turned off any virus-checking software that may be running.
- You have exited all other applications.
Procedure for driver installation
First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below.
Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears.
Select a language
Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window.
Custom Install
Step 1: Select the software to be installed.
Select the programs you want to install from the list in the Custom Install tab.
Step 2: Install the driver
Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display.
- PTP Drivers
Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP.
- COOLPIX Camera Drivers (all models except 990 and 880)
Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition.
- Drivers for COOLPIX 990 and 880
Select this check box to install the drivers for the COOLPIX 990/880
- Drivers for D1 series cameras
Select this check box to install the drivers for the D1/D1X/D1H cameras.
Install PTP Driver (Windows XP only)
Check that the camera is disconnected
If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation.
Windows 98 SE
If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue.
When you install the device driver, the dialog box shown below may be displaye
Windows 98 SE
Windows ME
Windows 2000
Before installation
Select a language
Custom Install
- PTP Drivers
Windows 98 SE
your links dont wok ples helps me
