SOURCE: motor runs, doesn't freeze
ok if compressor is running the you have a leak or restriction if frezeer is under five years old call the manufacture to get it fix but you have to be sure is running if is not running the it just might be the overload repl it and it will start again
SOURCE: kenmore upright freezer no digtal light no motor running
This could be a bad controller since you had a power outage, or even a bad motor. Look in your operator's manual and see if there is a reset button somewhere near the motor.
Unless you are well versed in electronics and have the proper equipment, you'll be unable to diagnose the control board anyway.
As a last ditch effort, which sometimes works, unplug it for about 5 minutes and then plug it back in. Make sure your thermostat is turned to the correct setting.
SOURCE: My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
SOURCE: We have an E388 upright freezer...motor is still
dear sir/madam
i think your freezer,s indside motor is faulty so its not rotating motor is not working so freezer ,s evorator cycle is not having complete its reson for not cooling .
please contect to your freezer maintenance personnel for further action
hope answer the question
thank you.
please vote!
