The door to the soap dispenser works fine, but there is still half of the soap left after the cycle, and the top rack of dishes is always left dirty and greasy. I have taken everything out and dismantled all of the spray arms to make sure there are no blockages, and I have tried every combination of cycles. What else could be causing the problem?
The inlet water pressure need to check i think there is weak level of water , check 1st nearest tap to sea normall flow of water is good or not ?
> if it is weak so the problem outside the dishwasher it is plumbing problem
>if it is good so the problem relate to dishwasher so chech the whole path of inlet water> i think this will solve the problem
thanks
