Question about Fisher and Paykel Aquasmart wl80t65c
Power cut problem during the rinse cycle. Machine keeps cutting out.
Machine won't get past the rinse cycle. Keeps cutting out about 2 minutes into the rinse cycle. Thanks, David
    Master:
  • Fisher and P... Master
  • 738 Answers
Check for faulty pump
Posted on Oct 26, 2017
SOURCE:
catriver
  • 878 Answers
SOURCE: Slow Filling only in rinse cycle
Tony, the fact that you are not receiving any error codes tends to leave me to believe that your cold fill hose filter may be restricted. Going by your model number you can enter this mode by having the power on at the source and off at the console. Press and hold the lifecyle button and then push power button. You should hear 2 beeps and then the display go blank. You can test the hot and cold valves by pressing how dirty up (hot) and how dirty down (cold). If you find the cold valve slow as in your rinse check for restrictions. If it were the thermistor, I would think you would receive an error code..Good luck.
Posted on Jun 06, 2006
SOURCE: Fisher and Paykal GWL 10 US - Stops before rinse
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Posted on Aug 20, 2007
  • 351 Answers
SOURCE: Machine stops during run time & lights keep flashing and beeping
it may be a balance problem
Posted on Mar 03, 2008
  • 998 Answers
SOURCE: FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Posted on Aug 06, 2009
SOURCE: I have a Fisher & Paykel IW812 Intuitive Eco.
I had the power cut problem too. When I called the repairperson they blamed faulty wiring. I haven't tracked this down to see if this is actually the case.
Posted on Oct 21, 2010
Cold water cutoff
Either or Both of the below may be the reason:
(1) Sensors have stopped working.
(2) Something is obstructing Drain System.
Call Customer Service Engineer.
Mar 29, 2014 | Bosch Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
What causes the manitowoc ice machine to cut off during the freeze cycle
most of the problems on ice machines is a restriction in water circulation due to no maintenance. Might need some cleaning to be done.
Apr 19, 2013 | Manitowoc SY0854A Self Contained 870 lb...
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Washing machine cuts out
The pump is over heating and cutting power.
Mar 30, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel Aquasmart wl80t65c Logo
297 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
