Is there a fix?
SOURCE: Changing message
I am a new voluntary worker to the charity. The operating manual is lost. I like to change the date and time on display. Can you help!
SOURCE: lost programing
From extension 10.
you have to set the ringing.
feat 00
left intercom twice
right intercom once
enter ext number
touch the lines util they display how you want them to ring
feat 00 when done.
To set the feature to p/u a ringing call
feat 00
left intercom twice
right intercom once.
press: ** (then press lines in order 1, 2, 3, 4, etc)
then press ** again.
feature 00
repeat both for all extensions.
SOURCE: Lucent Partner 18D - stop ringing of line 2 at phone
From extension 10 or 11
Press feature 00
Left intercom
Left intercom
right intercom
enter your extension number
all lines that are programmed on your phone will light up.
Solid means immediate ring. Slow flash means delayed ring. Really fast flash means no ring.
Press the line you wish to not ring, 2 times.
Feature 00 when you are done.
SOURCE: We have a Lucent Partner
You need to purchase ASA DXD card. Can do it at ivdsonline.com they can help you set it up as well
SOURCE: Hello.. We have the parter-18D phone system. one
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Testimonial: "This info was very Helpful... I was able to program 2 phones.... Thanks!!"
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
