How to set the tax
First, to make sure it will work, your fax machine should be going directly to the phone jack, with the answering mach/phone (if any) going to the ext port in the back of the fax machine. That way, the fax machine can "eavesdrop" for any fax tones for every call.
If you want to use the fax machine to work with an answering machine on the same line, make sure to set the answering machine to 2 rings lower than the fax machine. Let's say, you have the answering machine set to 4 rings, your fax machine then should have 6 rings. You can set the number of rings for your fax machine under "basic fax setup" of the "menu". Otherwise, you can set the fax machine to auto answer by pressing the auto answer button.
