There are 3 methods to format the phone
IMPORTANT: back up your phone and memory card first!
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore.
note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area.
Nokia Code : *#7370# : NOKIA Format phone (Soft Reset)
Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset)
Found these in the N95USERS fourm.
Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button
While holding this combination press the power button once to start the phone
Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable.
Then select Mass Storage mode on the phone.
Once you PC has installed the Mass Storage device you can format the card from My Computer.
Note: assuming Microsoft Windows XP or VISTA.
Billman87
How to Format N95 ?
* + 3 + Calling key + On/Off key till formatting appear, Other wise flash ur phone
To format nokia N95 use :
Soft reset code *#7370#
Hard reset code *#7780#
*=Turn off the mobile device. Then press and hold “3", the “Green button” and “*” - Turn on and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
How to format phone memory of Nokia N95 when los lock kode
My N95 is restarting on its own. so couldnt use it. pls help
Format nokia n95 8gb
I have a nokia n95 8gb whenever i start my camera display is being black and when i play video also same problam wat should i do plz tell me its software problam or hardware i have also formated my mo:
How to unlock phone lock code if I forgot the password that has been changed. sony ericsson k800i is the phone model
εκανα αναβαθμησει σε nokia N95 και εσβησε η μπαταρια του πως γινεται να το επαναφερο? καποιος να βοηθισει ευχαριστο{greece)
I have lost my nokia n95 code pls help me
Find your solution from the list,
Nokia N95
Codes:
Software & Hardware Problems
Find Your Solutions for Nokia Phones:
Nokia N70
Nokia N73
Nokia 6300
Nokia 6600
All the other Nokia Phones.
My phone don't have a sim card but I can't use my phone at all. Everytime I turn it on it tells me usim is not ditected. What can i do to reset my phone/
Allritgh sooo for the ` BigMounth FreeCallers `
You can make free phone calls with GA628 (also work on other models)
NOTE: This trick has only been reported working on PREPAID GSM CARDS and in some countries and with some software versions.
The prepaid GSM SIM CARD is a kind of "SIM card" which only has a certain amount of credit on it.
Here's
the trick: Dial the number normally and press YES. While "connecting"
is shown on the screen, the following procedure should be carried out:
Press
CLR then 0 then # and then NO (twice) so as to switch OFF the phone.
You can then still speak on the phone while it is switched off but the
SIM card does not record your calls which will lead to FREE phone calls
in some countries.. I hope!!
http://shyntaxx.tvn.hu/target.htm
Type *#7370# into the phone while on. Remember to back-up your data using the Nokia PC Suite. Also make sure you remove your memory card if you have one, and remove the password from the memory card before you try to reformat.
*7370#
Their are main three Ways to Format N95 or any other Symbian Mobile:
1. By Reset Factory in Settings
2. *#7370# or *#7780# for also refresh
3. By holding Bulltons, Green Button Of Call, Button "3" and "*"
No Matter If any confusion Contact me
[email protected]
HOW TO FORMAT MY N95
how to format my phone memory of N95 ???
my device stops at the nokia screen. nothing happens after that. now how do i format it coz i think the software needs to be reinstalled....plz help
i forgat my user lock code
HELLO,
PLEASE HELP ME OUT
PLZ HOW CAN I FLASH ME MOBILE PHONE NOKIA N95
PLZ CAN YOU PROVIDE ME THE SITE WHERE I CAN GET THE SOFTWARE WHICH I CAN USE FOR FLASHING
PLEASE HELP ME
I LOVE YOU ALL
MAIL ME: [email protected]
hello...actually my n95 got a problem every 2 minutes the camera will on automatically...please help me! i already format the by the 3 ways that u mentioned but it didn't work....
how to format nokia n95
how i can format my hp n95
when playing the mp3 in my phone it does not sound out
and when i have an incoming call it does not ring out also.
Does anyone know how to format the Asian Version of the N95 8gb because none of the codes work on this one?
plece gude me how to use n95gb gsm to cdma
i cant format my mobile n 95
Hi How can i flash my vodafone Nokia N95.
how can i reformat my N95 if my phone gaurdian asking for lock code or pasword but the problem is i cannot recall my password and lock code. pls help me to fix my problem.. pls pls pls
my N95 is restarting on its own. so couldnt use it. pls help
nokia n70
When I turned on my N95, the screen shows nothing but blank white screen. Please let me no how to solve this problem.
Best Regards
Zahid
i have nokia N95 chinese , i try to use the code *#7780# and the code *#7370# , but it doesn't work , why ?
When I turned on my N95 8gb, the screen shows nothing but blank white screen. Please let me no how to solve this problem.
i hane problem with my n95 that i changed the lcd screen and 2 days after working after i connected it to the computer i found it hanged and no response. normally it turn on /off with no problems
but the keys no response i suspect there is a virus on the phone memory
forgot my security code
n95
my phone not giving proper battery back up but battery is good..
what the fault
it doesn't let me use any of the key accept the on/off buttons
Hi 2 All.
I have a chines mobile its name is Nokia N95 - 8GB.now it has no memory card inside and when i take pitures its only take 5 picurtes and say disk full.i don't know how can i soft and hard reset it.and also it not recieve bluetooth.please help me.
hello there ,, i forget the password can help me how to format it
