Question about Tag Heuer Watches
What type of swiss quartz movement is in a tag heuer aquaracer waf1010 ba0822?
    Problem Solver:
  • 19 Answers
ETA or F0 movements are usually tags number 1 choice of movements.
ETA G10.711
Posted on Jul 14, 2009
6ya staff
SOURCE:
If the stem does not lock in, will it still be waterproof?
You need to get out your jeweler's loupe (best at 5x & 10x)... and look for the threads to "*****" (ski-rue) down your winder-stem (not a lock).
(Features a Ski-rue down crown & back case)
YOU can pretty much be assured that if the "stem" collar is malfunctioning (broken) the "water-proof" element is compromised (that's most likely the least of your troubles).
More importantly... if the STEM does not properly "tighten" it can
cause further damage against gears which MUST align with it... further it can come all the way out and be lost... Not an inexpensive part.
Best direction would be to get it serviced by an authorized agent.
TAG Heuer Aquaracer 500M Quartz Mens Watch WAJ1110 BA0870
TAG Heuer Aquaracer WAJ1110 BA0870
Jaxa style Suissetek XL Wrench Case Opener for Large Screwback Watches
Mar 30, 2016 | Tag Heuer Aquaracer Quartz WAJ1110.BA0871...
Tip
TAG HEUER Aquaracer quartz chronograph manual.
Follow this link and download original TAG HEUER Aquaracer quartz chronograph manual: http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1110.BA0804
on Feb 09, 2010 | Watches
The winding knob does not lock when I press and turn
That means you need a new stem. Stem problems are fairly common on Quartz Tag Heuer watches. Should not cost you more than $100.
Nov 10, 2013 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have a CAN1010 TAG AQUARACER CHRONOGRAPH and whe reset it the second arm doesn't reset to 0 but instead stops 2 seconds before..
This works! Loosen the bezel all the way. Pressing the bottom button, press one time the topmbottom and see how the chrononhand corrects by one second towards zero. Do it again and have it reset. Tighten the bezel. Thats it
May 13, 2011 | Tag Heuer Aquaracer Quartz Chronograph...
I have an ct1115 tag heuer aquaracer chronograph and the caps to the buttons on the side fell off easy fix? you can push them with your nail the watch still works etc. the covers are gone
The pushers sound like they have fallen off.This is quite a common problem.Take care as the watch wont be waterproof.The parts will need to be obtained from TAG and fitted by a watchmaker.Return the watch to an agent for them to attend to or find a watchmaker that can get TAG parts.
www.rolexrepairs.co.uk are specialist watchmakers that could help.
Regards
Aug 04, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
Good Morning, How do you zero out the hour and minutes? Also I can not zero out the minute hand. Thanks
If you go to "http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1111.BA0803" you will find a link to user instructions on the right of the page.
Mar 14, 2010 | Tag Heuer 2000 Aquaracer Chronograph...
My tag heuer aquaracer has a problem: the second hand stops and then speeds up really quickly for about 5 seconds. any idea why/how to fix it?
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4-5 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Mar 11, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch.  Change the battery, and see if the problem goes away.  If it does not, then it could be a problem with the stepper motor, which will require a watchmaker.  Of course all of this is dependent on the assumption that your watch has a quartz movement.  If it is an automatic, or mechanical you have bigger problems.
Oct 19, 2007 | Tag Heuer WAF2110.BA0806 Aquaracer...
Watches Logo
280 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
