Http://www.manualslib.com/manual/529074/Olivetti-D-Copia-200mf.html?page=126#manual
Tells you how on page 4-10 above.
The attached link allows you to read whole instruction book online by either entering page x of xx at the top or scrolling previous and next with the arrows. Hope it is for the correct model and that helps.
SOURCE: how to change the paper size in olivetti copia d 20 w copier
In pallet install to limiters as is done on sectoring, but with inverse, distant sides install the plastic insertions as defined, there there is helps with instruction format.Good luck!
SOURCE: I have a copier olivetti d-copia 20W, after change
olivetti d-copia 20w
F2 signal whit is the problam
SOURCE: my photocopier is just saying reset all originals in DP how do i reset
Open and close the document feeder (where you put your pages that you want copied), take out any papers on there and place them back in the document feeder. press the start button. Good luck !
SOURCE: C-6 and 400 error on olivetti d-copia 200
cant find c6 or 400 in the manual. make sure all the doors are closed 1 st
