Moultrie Game Spy M-880 Logo
A
Anonymous Posted on Oct 08, 2015
Pictures in the dark are really dark, what can i do? i just bought the camera today, batteries are charged.
I purchased a Nikon D3100 yesterday. I tried taking some pics today but I cannot view the pictures in LiveView. When I click the button all I can see (in LIveview) is a dark or balckened screen. HELP!
Hi dear mount11zion, are the battery full charged?,please verfy.Charge the battery about 2 hs..
If still remains dark without any information go to dealer asap.
Regards
1helpful
My camera works fine for awhile, and then the screen goes dark, but you can still see some movement. Pictures turn our dark with blue tint. I've tried charging the battery, and battery appears to have a...
This sounds like a problem with the image sensor within the camera. I doubt camera charge will affect picture or LCD screen image quality. Such problems can occur with old camera and in most cases buying a new camera is indicated as repairs are expensive. Ask at the Casio website support.
Please rate Fixya Answers.
5helpful
The problem is that u know the sony hdv xr500x when u put it on the picture is very dark we have tried it under light too put but the picture is still dark
Hello
When you look at your pictures are they dark, murky and hard to see? If you took pictures at a wedding, dance recital, theater performance or any indoor event and they came out dark, read on to learn why your pictures are dark, and how to fix this common camera problem.
Many people take pictures of indoor events, only to be unsatisfied with the final outcome of their photos. Although you may have bought the top of the line film or digital camera, there are a few limitations that you need to know about.
To correctly expose your pictures, you camera needs a lot of light. The compact point and shoot varieties adjust for this when you're outside during the daytime, and usually your pictures turn out fine, right? Well, then how come when you take indoor pictures, they sometimes come out too dark? There are two culprits; your zoom function and your flash.
Most compact cameras today offer a zoom function. When I used to work in retail photography sales, the first feature that consumers would ask for is zoom. People love to get close-up pictures without using their feet. Although zoom does bring your subject matter in closer, it also decreases the amount of light that can get into your camera. Essentially, the more you zoom, the less light your camera can receive, and your pictures will be darker.
So, if your taking pictures indoors, in a dark church, gym or other window-less room it is very difficult for your camera to get enough light to properly expose your pictures.
This is when most photographers decide to turn on their flash. The flash on your camera is a great tool to illuminate dark situations that are in close proximity to the camera. Most built-in flash units are designed to allow the light to travel 8-10 feet away in poor quality light and up to 15-20 feet in brighter situations.
What most camera users fail to realize is that although your zoom function is visually bringing you closer to the action, you flash cannot reach that far to illuminate the subject, and your pictures will be dark.
Hope it helps, if so do rate the solution
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Camera drains battery while off
Assuming you're fully closing the front slider cover, the power switch is activated by the front slider cover so it may not be activating the switch or sensing that the cover fully closed. Sounds like it needs a professional service.
Dark Pictures
Hello Cowgirl, It sounds like the camera settings have been changed in the menu.Check to see if all control items are set to "AUTO"
This should take care of problem.The camera did not go bad not being used.
Best Regards, Russell
4helpful
2answers
DROPPED NIKON d40, now my pictures are all dark
First u have to reset the camera,go through the menu and select reset and yes. the camera will take default settings.Try now.
Reset the camera opening the connector cover.
You try with a different compatible lens .If works we have to change the lens.
Remove the battery and get fully charged .Operate all switches for some clicks. then put the battery and try.
Then u have to consult a mechanic.
NIkon Coolpix 2100 Digital Camera
Change the setting off from automatic. Choose Flash for all your pictures.
Artgirlny
Finepix f10 problem
Plug came off the wall? What do you mean by this, the plug to what exactly the charger? How is the charger camera battery set up? Where is the red light on the charger? More detail please
Camera shut off during photos and will not turn back on
camera is not not recoginising the battery may there be a battery type mismatch or battery type is not provided correctly in the software of camera
Top Moultrie Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
