2005 Suzuki XL7 - Without speaker - Carpet Dash Cover Logo
e
eldridge mcdougall Posted on Oct 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the torque specification for rod bearings and main bearings
Claude Kayser
Level 3:
Top Expert:
  • Coverking Master 9,098 Answers
  • Posted on Oct 07, 2015
Claude Kayser
Coverking Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063310
Points
28436
Main Bearing Bolts Torque Suzuki XL7 2.7 2003 - Fixya
www.fixya.com/.../t15635769-main_bearing_bolts_torque_suzuki_xl7_...
Jan 2, 2013 - Main Bearing Bolts Torque Suzuki XL7 2.7 2003 - Suzuki 2002 XL-7 ...What are the torque specs for cam caps on a 2005 Suzuki forenza 2.0 ... Need torque specs for 1.3 liter motor,connecting rod bearing and main bearings.
Need torque for ford wlt 2.5L turbo main bearings and conrod bearings
The torque specifications for the main bearings and connecting rod bearings in a Ford WL/WLT 2.5L Turbo engine may vary depending on the specific model year and engine configuration. However, as a general guideline, here are the torque specifications for the main bearings and connecting rod bearings in this engine:
Main bearings:
  1. Torque the main bearing cap bolts in three stages in the following sequence:Stage 1: 30 Nm (22 lb-ft)
    Stage 2: 80 Nm (59 lb-ft)
    Stage 3: 90 degrees
  2. After the final torque of 90 degrees, check the bolt stretch with a torque angle gauge. The stretch should be between 0.15mm and 0.30mm.
Connecting rod bearings:
  1. Torque the connecting rod cap bolts in two stages in the following sequence:Stage 1: 30 Nm (22 lb-ft)
    Stage 2: 90 degrees
It is important to note that these torque specifications are general guidelines and may vary based on the specific model year and engine configuration. Always refer to the manufacturer's service manual or consult a certified mechanic for the exact torque specifications for your specific vehicle
Please can you help with all the torque settings for the cylinder head on Hyundai Accent 1.5 1995"
Nissan Frontier, Xterra 1998-05
Torque Specifications
Fig.
TORQUE SPECIFICATIONS
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1998 2.4 (2389) KA24DE
1A Step 1: 22 ft. lbs.
2B 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
4C The cylinder heads and the lower intake manifold are installed together
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1999 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 3.3 (3277) VG33E
1A The cylinder heads and the lower intake manifold are installed together
3C Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
4D Step 1: Tighten the connecting rod bearing bolts to 10-12 ft. lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1998 KA24DE
1- Step 1: 22 ft. lbs.
2- 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
3- The cylinder heads and the lower intake manifold are installed together
4- 10-12 ft. lbs. +60-65 degrees
5- Step 1: 72 ft. lbs.
6- Step 1: bolts 11-22 19 ft. lbs.
7- Step 1: 20 ft. lbs.
8- Step 1: 31 ft. lbs.
9- 83 inch lbs.
10- Stud bolt: 11 ft. lbs.
11- Step 1: 72 ft. lbs.
12- Bolts: 17-24 (M8) 16 ft. lbs.
13- Step 1: 33 ft. lbs.
14- Intake manifold collector:
15- Intake manifold:
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1999 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2000 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2001 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2002 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2003 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2004 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2005 QR25DE VQ40DE
9- 83 inch lbs.
Main Bearing Torque Sequence
Fig. Main bearing torque sequence-2.4L engine
Fig. Main bearing torque sequence-2.5L engine
Fig. Main bearing torque sequence-3.3L engine
Fig. Main bearing torque sequence-4.0L engine
Want isusu reward 4hg1 engine torque specification
I need all the specs of Isuzu npr 4hg1 engine.Cylinder head bolts torque, crankshaft bolts torque, connecting rod caps bolts torque
2helpful
2answers
Engine connecting rod torque specification.
contact autozone or dealer service for specs..
I need accurate torque specifications for rod and main bearing caps for a 2.0 liter 96 Eclipse turbo
I need accurate torque specifications for rod and I need accurate torque specifications for rod and main bearing caps for a 2.0 liter eclipse turbo 90 help plis
1helpful
Does anyone have the bolt torque specifications for a ford 1995 5.8L. I need the cylinder heads, crankshaft mains and connecting rod torque.
Head bolts, 105-112 Foot pounds (Final torque)
Final torque must be reached in 3 equal steps. Recheck final torque in sequence.
Main Bearing Caps, Torque in sequence Step 1: torque to 50 Ft/Lbs Step 2: torque to 105 Ft/Lbs
Rod Bearing Caps, 45 Foot pounds (Final torque)
2helpful
Torque specs for 1.5 kia rio connecting rod
TORQUE SPECIFICATIONS kia rio
Cylinder Head Bolts:
(21.7ft.lb) or (3.0kgf.m) 90?
Top Coverking Vehicle Parts & Accessories Experts
john h
Jonathan Buck
Jonathan Buck
Are you a Coverking Vehicle Part and Accessory Expert? Answer questions, earn points and help others
