Hp laserjet mfp m1132 showing error E8. can print but cannot copy/scan
Hey!
I have also been facing the same issue on my laserjet printer. Which I resolved with the help of the assistance of Hp Technical Support Phone Number.
Visit the Website:-https://www.hptechnicalsupportphonenumber.com/blog/fix-hp-laserjet-m1132-printer-error-e8/
Now No need to refill or change any parts of TONER CARTRIDGE... BECAUSE Now toner Cartridge @350/- with unique scheme in MUMBAI only
save your printer's life.....
9987779811
lasertoner.in
Juliet. Most likely the scanner lamp, or scanner control unit assembly is defective. If you're technically savvy, you could remove the scan glass and lube the shaft that the scan lamp assy slides on. Sometimes that will fix it. Otherwise, the whole top scan unit will need replacing. That could cost over $300 for the replacement.
