K
Kathy Pickus Posted on Oct 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
I print my shipping labels through PayPal multi order shipping which depends on Pitney Bowes for connection to USPS. Recently Pitney Bowes switched to a PDF print job instead of a java print job for the shipping labels. I have to choose the Zebra printer in the print dialog box, adjust the print options to the correct size label and then I am able to use the Zebra printer. The first two labels will print with the text correctly spaced. Additional labels printed will have incorrectly spaced text for the to/from address. However, the bar code number prints correctly. I have not been able to find any answer to this on the internet in Zebra forums. I would be happy to send a copy of a label showing the problem.
Nick
Level 2:
Sergeant:
Habit-Forming:
  • Zebra Expert 124 Answers
  • Posted on Oct 13, 2015
Nick
Zebra Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
124
Questions
Helped
43717
Points
534
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Zebra LP 2844 printing off center
If your Zebra LP 2844 printer is experiencing shifting or off-center printing, there are a few possible causes and troubleshooting steps you can try:
  1. Check print settings: Ensure that the print settings on your computer or label design software are correctly configured for the label size and layout you are using. Make sure the label dimensions and print margins are set accurately.
  2. Calibrate the printer: Perform a calibration on the printer to ensure it is properly aligned. To calibrate the Zebra LP 2844, follow these steps: a. Turn off the printer. b. Hold down the feed button. c. While holding the feed button, turn on the printer. d. Release the feed button once the green status light begins to flash. e. The printer will feed labels and automatically adjust the label alignment. f. Once the printer stops feeding labels, the calibration is complete.
  3. Adjust label position sensors: The LP 2844 has label position sensors that detect the start of each label. If these sensors are misaligned or dirty, it can cause shifting or off-center printing. Clean the sensors using a lint-free cloth and ensure they are properly aligned.
  4. Check label alignment: Ensure that the labels are loaded correctly and aligned properly in the printer. Make sure they are inserted straight and centered in the label guides.
  5. Inspect the print head: Check the print head for any debris, adhesive residue, or damage. Clean the print head with isopropyl alcohol and a cotton swab if necessary. A dirty or damaged print head can affect print quality and alignment.
  6. Update or reinstall printer drivers: Ensure that you have the latest printer drivers installed on your computer. If the drivers are outdated or corrupted, it can cause printing issues. Visit the Zebra website and download the appropriate drivers for your LP 2844 model.
  7. Test with different labels or ribbons: If the problem persists, try using different labels or ribbons. Sometimes, the issue could be related to the specific media being used.
Is it my pc or my zebra printer?
Go into printer options and select "Fit To Page"
I have the zebra lp 2844 i'm trying to print from ebay everything is working ecept when i print the label only two line print. i did a test page and it comes out fine i have calibrated the printer and...
Check that your printer setup software is "setup" correctly (AKA printer properties in "control panel" or "devices & printers").
Look at the "label size" and orientation (portrait or landscape) in the printer setup, that may be wrong and cutting off the rest of the printout. If you indicate more printer buffer size that what there is, that to might cause problems.
Other things to check for: Do you have the correct print driver for your OS?
Make sure you have the correct printer selected in Ebay. I don't use Ebay to print labels out with my thermal printer, but I use paypal and I believe they are very similar if not the same. Also, in paypal anyways, you have to have the correct run-time version of JAVA installed in order for it to work properly. Don't know about ebay, but that might be something to look into.
2answers
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
2answers
Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
2answers
Zebra Thermal 2844 prints text poorly
Lizardlick,
I found this information in the user manual:
Let the print head to cool for one minute, then use a new
cleaning pen to swab the print elements (the thin gray
line on the print head) from end to end. NOTE: You do
not have to turn off the printer to do this.
If print quality remains poor after cleaning, try the
Save-a-Print Head cleaning film to remove buildup
without damaging the print head. Call your authorized
reseller for more information.
Just installed my 2844
Bask11,
sounds like the printer needs to regap itself. Turn the printer off, hold the feed button down and while holding the feed button, turn the printer back on. As soon as it flashes, let go. It will regap itself. When it stops moving, press the feed button once and there should be a priinted line that says 'out of dump'. The printer should be ready to go then.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
