Refrigerators Logo
A
Anonymous Posted on Oct 06, 2015
General time Corp movement ice citron 100 model 73035. It was made for a company called Yarbrough time ltd. Someone wrote 2/5/1973 on the back. Can anyone give me information about the age and value
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Nov 19, 2007
SOURCE: Lost warrenty Information
http://www.akai.com
Anonymous
  • 10 Answers
  • Posted on Mar 25, 2009
SOURCE: Needed English User manual of Model BBK9916.
posted the russian version of the manual for your DVD Recorder in HTML.
go to this address.  http://translate.google.com/translate_t?hl=en#
enter this address. use exact case.   www.jrgimaging.biz/DW9916S.htm
Select Russian from the Pulldown and hit translate.
Some of it is translated.
I have a PDF of the manual but it is in Russian. If you can find a PDF translator it will probably work better than google translate.
gopakumarg43
  • 76851 Answers
  • Posted on Oct 23, 2010
SOURCE: i has purchased philips tv model no.slim 21 PT
Hello
I don't know your nationality. If you are in India you won't get anything for this damage, because all TVs sold here in India bears only one years "Service Warranty". No company here provides replacement gurantee. Means if the tv gets repaired within this period of time, the service center will repair for it for free, but you have to pay for the components replaced. In fact they will charge the price of the components plus service, and bill it all as components price.
If you are in India, it is better to get rid of it soon for that offer. But before that you must enquire about the exact price of the thing you wants to buy from them, because they will charge the price of the thing you buy plus the cost of the TV you are going to give them first, and will give a certain amount of discount for it. In fact you are giving the tv to them absolutely free. Did you got me?
This is the business trick of every business men in the world, where ever they be.
Anonymous
  • Posted on May 16, 2011
SOURCE: sir i want to know
IMFINITY India pvt. Ltd. or Excelsoft technologies, NOIDA is one of the worst firm to work into.
They have absurd working atmosphere. Abusive behavioral environment and dominating nature of the management are their greatest assets. They make u work like an fool other than ur profile area. No timely salaries, No canteens, No work timings, No security for girls.
These types of companies are present only to spoil a good employees career.
If you are not good at politics you are bound to resign in the initial stages of you job. Even if you were recruited as a Team Lead or manager.
They gave false information before joining them as they are CMM level certified. They dont even have a single certification of standards.
Notice period they ask is for 3 months ; even if u serve that they will not relieve you with proper relieving letters or full and final.
Bogus company with bogus management.
Anonymous
  • 3773 Answers
  • Posted on Sep 26, 2011
SOURCE: I have age adora refrigertor
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
1helpful
WHERE CAN i OBTAIN THE INSTRUCTIONS FOR A STEAM GENERATOR IRON THAT i HAVE BEEN GIVEN. MODEL NO.8548 BY IDEAL SOURCING LTD
Marion, I've scoured the internet and I am stumped. I'd call Walmart or someone that sells them and see if they've got one laying around or email the company.
Dec 30, 2018 • Irons
2answers
I have a strategic vista corp. ccd camera model no. MC- 113s and i can't find any wiring diagrams for it anywhere. Can someone please help me?
You will not find any diagrams, they are not made available to the general public. Sorry just the messenger.
2answers
Spt ice maker
if only a few months old - WARRANTY - call the company or the store which you bought if from.
29helpful
6answers
Micro Leasing & Funding Ltd. Company is a RBI or SEBI Controlled ?
MICRO LEASING AND FUNDING WHICH IS NOT EVEN REGISTERED WITH RBI IS COLLECTING CRORES OF RUPEES FROM PEOPLE. TO HIDE THEIR MIS DEED AND MAKE INVESTOR FOOL THEY HAVE OPEN A TV CHANNEL CALLED MBCTV. ALL THE INVESTOR WHO HAVE INVESTED IN MICRO LEASING AND FUNDING SHOUDL ASK THEIR DEPOSIT ALL FILES CASE AGAINST ITS MD TO GET THE MONEY BACK>
Whirlpool single oven model AKZ146/WH. Oven not working, had power failure and display says 'stop' and tried everything in manual, doesnt help, cannot change time or get over to work. I have had...
alot of times when power goes out and then comes back on the power serge can take out the clock assy. you can either change out the clock assy. yourself or call someone in to do this and send the bill to your electric company,have done this before,one customer lost his oven and dishwasher and electric corp. paid the bill.this sin't just the clock it has all the relays on the computer board everything to run the oven,it all goes through the clock assy. the model you sent doesn't show up,you have to find the tag on the oven and give it to the parts store to order the correct part,if the overlay is white for some reason white overlays don't come off,if it's black you can heat it up with a hair dryer and use a putty knife to peal it off and stick it on the new clock assy. good luck.also if this is an older oven you might not be able to get the part you'll have to send it out to get rebuilt or contact your electric corp.tell them the part is no longer available and they'll have to replace it for you.i would call them as soon as possible all they can say is no they won't help you out but here in mass. they do.
3helpful
I have a Ricoh watch that has " ATRANTA Water Resistant 10BAR" on the face. Face is red in colour, has day and date scroll. Day of week can be seen in English or (guessing)Chinese or Japenese script. Back...
Ricoh Elemx AT Corp. is subsidiary company of Ricoh Elemex Corp.
The Hamilton Ricoh Watch Company, Ltd. was a joint venture (60% owned by Hamilton) and only existed between 1962 and 1964. Electric parts were made in Lancaster, PA while the mechanicals parts were made in Japan, the watches also being assembled in Japan. The movements are marked "Ricoh 555E", but are the same as the Standard Time Corp. 130E (fitted in Hamilton's Vantage range), which in turn is very similar to the Hamilton 505.
Although the factory was turning out 1000 / month, very few were sold. Marketing was handled by Ricoh but they failed to break the stranglehold and monopoly that Seiko had in the Japanese stores; in the end, most were sold on US military bases in Japan.
The partnership was dissolved in 1965; some of the Hamilton Ricoh movements were re-cased as Vantage and sold in the US.
Now Ricoh is owned by Elemex and they still producing watches. Follow this link and see for yourself:
http://www.ricohelemex.co.jp/en/products/req/
Unfortunately, I cant give you any details about your watch, except that the 10BAR means your watch can withstand 10BAR pressure, and that is 10 meters under water.
The bar (symbol bar) is a unit of pressure equal to 100 kilopascals, and roughly equal to the atmospheric pressure on Earth at sea level.
Rate me, please.
Feb 28, 2010 • Watches
Emerson Plasma tv
connect ear wireless ear phone
3helpful
Need replacement parts
Unfortunately, Nostalgia Electrics has stopped (AGAIN!) production of the ICM-517 and ICM 562 Soft Serve Ice Cream Makers. And the company customer service is a "bear" to get a call back from. You could go to the Helman Group, LTD website or the Nostalgia Electrics website and click on customer service and type in your request, but don't expect a quick answer. And there is an 800 # to call also, but you will only get the voice mail and leave a message. No live person, just a call back, if you're really really good and really lucky. It's a shame they have so much trouble with these, they seem to do well with the Popcorn machines, cotton candy, and drink machines, hot dogger, ect. You'd think they could debug this one too. Kindest regards, Joe.
Top General Refrigerators Experts
vince
Paul Bade
Arnie Burke
Arnie Burke
Are you a General Refrigerator Expert? Answer questions, earn points and help others
