Question about Razor Dune Runner 350 Go Cart
On a traulmaster 150 cc xrs gokart how many wires go in cdi box
Tao Tao Lancer-150 CDI location
Hi, Thomas for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Tao Tao, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Tao Tao Lancer 150 CDI location Google Search
How to replace the cdi box on your scooter with performance cdi box
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
https://taotaopartsdirect.myshopify.com/collections/lancer-150
TAOTAO QUANTUM 150 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 25, 2017 | Motorcycles
2013 Vespa 150 LX CDI location
Hi, Anthony for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2013 Vespa 150 LX CDI location Google Search
http://manuals.wotmeworry.org.uk/Vespa/LX150/LX150Workshop.pdf
Vespa VESPA LX 150 2005 Parts
http://cdnmedia.endeavorsuite.com/images//organizations/05211b9c-b6c7-4840-8e84-2970c2318c24/2009-12LX150ie.pdf
VESPA LX 125 150 Euro 3 User Manual
Aug 16, 2017 | 2008 Vespa LX 150
My pulsar 150 cc dtsi won't start , I have cleaned the plug, CDI is also in good condition, but the bike does not start, what might be the problem. Help me plzzzz
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. Tip over sensor needs a reset.
18. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Review on Bajaj Pulsar by Jagdishahuja MouthShut com
Starting trouble with Pulsar 180 CDI Issue Team BHP
150cc scooter won start Plz help
http://www.bcmtouring.com/imp/Pulsar_DTSi_Workshop_Manual.pdf
Bajaj Pulsar 150 DTS User Manual
Aug 21, 2016 | Motorcycles
Is there higher output CDI'S for 150 cc scooters ?
no opoo ppopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopopo
Mar 31, 2016 | Motorcycles
2006 honda cbf 250 wiring diagram needed... or need to know what wires are what out of the cdi/ecu, I have tried everything and cannot find anything... engine has been put into gokart and need to rewire...
from ignition switch red wire supplies power from the battery to the ignition switch, black wires are live when the switch is on but have nothing to do with the cdi The cdi is supplied by the generator on your engine.Green wires from switch are all earthing wires.The black and white wire coming from the switch is the wire that puts the cdi to earth to disable the ignition in the off position .
Dec 17, 2014 | Motorcycles
150 cc bike
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.How to replace the cdi box on your scooter with performance cdi box
How To Fix Replace GY6 Flywheel Cdi Stator and Magneto
Bajaj Discover 150 2011 service manual DOWNLOAD FREE FULLMANUALS COM
bajaj Auto Spare Parts List All 2013
Bajaj Auto Discover 150 User Manual
Oct 26, 2013 | Bajaj Motorcycles
Is there anyone who can fix a Baja 150 cc in Texas?
Hi, Ryanrayminya for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.My Scooters and ATVs Discounted Prices
Houston ATV Repair GoKart Repairs Dirtbike Repairs and Dune Buggy Repair...
Best Scooter Repair in Austin TX
http://xplicitmoto.com/index.php/aboutus
San Antonio TX scooter repair Find scooter repair in San Antonio TX
Jan 25, 2011 | 2000 Bajaj Chetak 150
Razor Dune Runner 350 Go Cart Logo
35 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
