Computers & Internet Logo
Posted on Oct 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the difference between E & P on 6400E SDRAM and 6400P SDRAM
I have an HP workstation xw4600 it takes DDR-2 240 pin 800Mz unbuffered ECC modules. i am running 2x2gb Crucial CT25672AA800.M18 FG DIMM 6400E sticks and would like to increase my SDRAM, I have found 2x4gb Hynix DDR-2 240 pin 800Mz 6400P sticks. or can you tell me what 4gb sticks will work.
jdthefixer
Level 3:
  • Master 747 Answers
  • Posted on Oct 05, 2015
jdthefixer
Master
Level 3:
Answers
747
Questions
0
Helped
314473
Points
2412
"P" stands for "parity" and "E" stands for ECC (Error Checking & Correcting)
To determine which memory modules will work in your PC, visit the Crucial web site at: www.crucial.com and use their memory selection software. You will have to allow the site to scan your system.
1helpful
2answers
Can an old HP Workstation xw8000 Computer that is currently using 512 RAM (PC2100 registered 184 PIN ECC DDR SDRAM DIMMs) be upgrade using 4GB Kit (2 X 2GB) PC2100 Registered 266MHz 184 pin DDR SDRA
According to a couple of people I have conferred with, that RAM should work.
Take a stick of the old ram out and make sure the the cut out, in the new RAM, is in the exact place as the old sticks. It cannot be off by a micron, or it will not fit.
Understanding Identifying and Upgrading the RAM in your PC
Dont click on any of the ads in that article, just read it and you will be able to judge for yourself.
1GB PC400 RAM does not work with motherboard A7S266-VM/U2
Hello the home page is here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=10&m=A7S266-VM%2fU2&os=&hashedid=n%2fa
If any drivers or manual needed select first your windows.
Click on global for download.
Unzip the file and you need a pdf reader (adobe) to read the content.
Here are some specification about you mainboard:
2 x DDR DIMM Sockets
Max.2GB unbuffered PC2100/PC1600 non-ECC SDRAM Memory
2 x SDR DIMM Sockets
Max.2GB unbuffered PC133/PC100 non-ECC SDRAM Memory
(Note: DDR ram and SD ram memory can not be used on A7S266-VM/U2 simultaneously)
This means you can`t use SD RAM together with DDR ram.
The bios could have a setting for this because of the use of 2 different ram types.
Try downloading the manual.
Good luck
2answers
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
How can i use 1x2 pc2100r ecc mem modules on an l7vmm3 motherboard
Two 184-pin DDR DIMMs sockets for 2.5V DDR SDRAM (DDR266/DDR200)
Maximum: 1GB (Unbuffered Memory)/ 2GB (Buffered Memory)
Yes, regestered EEC modules are "buffered", so you should be ok at 2 gigs.
What ram compatible with intel845gv mother
Please find the details below:
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845GV
  • Error Detection Support: Non-ECC only
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 2.x Compliant
  • Thanks and regards,
    Anil.B.R
    2helpful
    2answers
    I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
    Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
    Slot 1
    Slot 2
    Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
    *Not to exceed manufacturer supported memory.
    • Chipset: Intel 845D
    • Error Detection Support: ECC and non-ECC
    • Graphics Support: AGP 4X
    • USB Support: 1.x Compliant
    Q: What memory goes into my computer, and will a faster speed be backward-compatible?
    A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
    Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
    Q: How much memory can my computer handle?
    A: 2048MB.
    Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
    Q: Do I have to install matching pairs?
    A: No.
    No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
    Q: Does my computer support dual-channel memory?
    A: No.
    Your system does not support dual channel.
    Q: Does my computer support ECC memory?
    A: Yes.
    Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
    2helpful
    3answers
    What is the maximum memory for this computer?
    This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
    How to install additional 256 MB memory
    You simply just push the memory into the DIMM socket on the motherboard. You need to use DDR SDRAM but should check what your I/O bus speed is set at. They make 4 different types of DDR SDRAM. They are DDR-200 (PC1600). DDR-266 (PC2100). DDR-333 (PC2700) and DDR-400 (PC3200). The following links should help you out:
    http://www.tech-faq.com/unbuffered-memory.shtml
    http://en.wikipedia.org/wiki/DDR_SDRAM
    P4S8X-X motherboard. Latest list of compatable RAM 1.gb
  • Chipset: SiS 648
  • 184-pin DIMM Banking: 3 (3 banks of 1)
  • Max Unbuffered DDR SDRAM: 3072MB
  • Graphics Support: AGP 8X
  • 0helpful
    Memory swap
    This is the memory specs for your board 4 x 184-pin DIMM Sockets support max. 4GB unbuffered non-ECC PC3200/2700/2100/1600 DDR SDRAM memory Dual-channel memory architecture
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
