Question about Xitel INport Deluxe for PC
Message given that device is unknown. Not able to
Tried to get the INport Deluxe to download its drivers by connecting USB to computer with device, but message given that device is unknown. Not able to get drivers to download with Windows XP system. Suppose to be easily connected. Didn't pass Step1.
Thats is solution,
Posted on Jul 13, 2009
SOURCE:
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
I keep getting an (code 1) when I try to install a device by way of usb port
(Code 1) Means the device is not configured correctly.  Try to update the drivers for this device, click Update Driver. If that doesn't work see your documentation for more information.
Regards. Bill
Oct 05, 2009 | Xitel INport Deluxe for PC
I lost ALL sound when Iinstalled Xitel's Inport
Have you trying to rollback using windows sistem restore
Aug 23, 2009 | Xitel INport Deluxe for PC
When I plug my 4gb flash it say malfunction and not recognize
have you tried putting it in a different usb port if you tried that try updating your computers usb drivers from the support site for the computer your trying to use the flash drives on
May 28, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb driver for intel 845 GVSR motherboard
u better install windows 7 or updated os in ur system bcoz microsoft had stopped the updates for xp os. so i can say u to install latest updated os to rectify ur problem
Oct 08, 2017 | Microsoft Windows XP Professional With...
INPORT Installed, Sound Disappears
The Xitel site http://www.xitel.com/USA/support_inport.htm says when this happens, " 1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA PROPERTIES -> AUDIO TAB
2. Make sure that in the Audio tab your soundcard appears as the Preferred Playback device with USB Audio or INport as the Preferred Recording Device. There should also be a check next to the option 'use only preferred device'.
3. When you start LPRecorder you should also make sure that Recording Device is set to USB Device or INport and Playback Device is set as your soundcard and that there is a check next to the option Simultaneous Playback."
Jul 20, 2008 | Xitel INport (HFLI1X1) Audio Input
No vista drivers
You should download the driver for Windows XP, unzip it (if not specified otherwise C:\temp\cs330_XP).
I guess that if you say the camera doesn't work it means you already tried to connect it to the USB in your computer. If so, right-click on "My Computer" and click on "Manage". Go to "Device Manager (under "System Tools"). You should see there a device named "Unknown Device". Double click on it and go to the Driver tab. click "Update driver..." and select "Browse my computer for driver software". Now, select the location you unzipped the driver to (as said before, usually C:\temp\cs330_XP) and click next until windows will try to install the driver. This can take from a few seconds to a few minutes. After a while (for me it took about 2.5 minutes so be patient) windows should say the installation was succesful.
Enjoy :-)
Aug 28, 2007 | Intel Deluxe PC Camera CS330 Webcam
Xitel INport Deluxe  for PC Logo
110 people viewed this question
Top Xitel Computers & Internet Experts
Marvin
Marvin
Peter Dragonetti
 Grubhead
Grubhead
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
