Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K Logo
s
steve weddle Posted on Oct 05, 2015
Why does my dewalt laser shoot 3 lines when on vertical but works fine on horizontal. Can i fix this problem myself?
1 Related Answer
John Trevino
  • 1420 Answers
  • Posted on Jun 18, 2009
SOURCE: DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Dewalt Laser Level 087 Vertical laser is fine. Horizontal laser bends. Is it possible to fix?
Lasers do not bend, per se. If you have some sort of distortion of the beam, then the reflector is faulty or damaged. If the beam is slanted then the gimble assembly is not hanging straight.
In either case these are throw away units. Go back to the retailer and see if they have a solution. Or call Black and Decker and see if they will replace it for you.
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
1helpful
How do I check if my dewalt spinning laser is accurate?
Set it up and shoot 4 level points around the laser . Like at 12 -3-6and 9 o clock. Move the laser 15 or 20 ft from where it is now and re-shoot those 4 points again .if they don't read level then your laser needs calibrated
3helpful
No laser beam how to fix
I would check the batterys first and if they are good, generally there is no way for an end user to fix a laser. I have talked to DeWalt in the past about this and been advised not to open it up. you can try to reset the laser and see if it reboots, sometimes they are so far out they won't turn the laser on.
4helpful
Horizontal line very dull , vertical line normal
if batteries are new then its either a bad connection to diode,cold solder on pcb or simply a blown diode
My dewalt heavy duty coil roofing nailer seems to misfire when shooting nails. The nails it shoots they come out slow, then it misses a bunch of them. I think the plunger is stuck. How do I get this...
before tearing apart spray gun plunger and shaft with carb cleaner than spray with a spray lube like wd40 sometimes the plunger gets debris on it if still misfiring call dewalts 800 number they can advise of local repair shop and also advise if problem can be fixed by u
6helpful
Line across picture tube
It's a bad solder connection on the vertical IC.It will be mounted on the main board.It is vertical in length and will have thirteen pins..should be marked "LA7838" or similar.
1helpful
2answers
SC 329 code Aficio 550
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the “Enter” key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Top Dewalt Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
