Hello, if the water in the radiator was quite low, before topping up, there could be an airlock in the system. Does the internal heater blow hot air? If it only blows cold air, even when the control setting is set to hot this indicates either low water level or air lock in the heater matrix or pipe feeds to it. Quite a few models have bleed valves on the pipe runs under the bonnet just before the bulkhead.
Hope this helps you.
SOURCE: maintenance required light
I just tried this and it worked!
I got it from this site:
http://lifeisafairytale.wordpress.com/2007/08/21/yaris-and-the-maintenance-required-light/
SOURCE: 1996 Nissan Sentra Idles Roughly, Cuts Off, Engine Light Stays On
if this is an automatic there will be a dip stick if it is a manual you do not use transmission fluid to find out what sencor is bad take car to advance auto parts they have a digatal reader and can tell wou what sencer went bad and where it is located
SOURCE: Engine light is on.
Your vehicle’s computer system has self-testing capability. When the computer senses that there is a problem with some of the components it stores the correspondent trouble code(s) in its memory and lights up the Check Engine or Service Engine Soon lights to tell you that there is a problem and you should have the car diagnosed and repaired. Not fluid related, but could be a small problem that's easy to fix now. Even a loose gas cap can turn the light on. Have a code scan, that's the starting point.
SOURCE: 2005 Honda Accord, 80K miles, (have not test
is it manual or automatic. If automatic bands might need adjustment. If manual maybe the clutch disc is not good does she smell like if something is burning when car is running
SOURCE: Coolant level and blue temp light
Manual states that when the fluid is cold it will show up blue then as it wanrms up it goes away. a normal function. It's in the owner manual somewhere.
BTW it's a VW Battle 2003
