Slide the write protect tab forward to remove the write protection. You cannot format it while it is write protected. Formatting will erase all data on the card. Install the card into a Windows or MAC and wait for the device to detect and mount the card. Use the appropriate procedure for the machine to format the card. See this procedure for additional step-by-step operations after the write protect tab has been moved.
You must first remove the write protection. Here is a link to a wiki article explaining the write protect removal process and how to format using Windows or MAC.
Hi Eric Chen,
there could be a couple of reasons the sd card is write protected,
1) Write protection enabled
- If it's the standard size sd card there's a switch on the left hand side.
2) May need to be reformatted
- First backup anything on the sd card to another location (ie: a folder on the desktop)
Go into you computer/file manager (some times called my computer) select the drive letter of the sd card (may listed as removal disk)
right click -> format, check that the right size is specified then click format (double check correct drive)
Then copy the files back.
Also you maybe able to use your camera to format the sd card instead.
Well somehow data on your usb flash is write protected, maybe before you locked part of your usb pen drive and losted that encryptor software on your usb.
Solution is next, find any software for formatting usb flash memory sticks, force format it and there you go. Thats about it! =)
To remove the right protection it is very simple, first remove your SD card in your mobile, the observe your SD card back to back, if you can see a small button you need to slide that button to remove right protection, then plug your SD card back to your china mobile and try to copay a folder,
Perform the following procedures when your digital camera does not detect the SD card.
1. Restart the camera
Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches.
2. Initialize the SD card
Format the SD card with your camera.
Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card.
When formatting the SD card, slide its tab upward to cancel write protection.
It is impossible to format the SD card while it is write protected.
3. Check if your camera detects other SD cards (If you own multiple SD cards.)
If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards.
If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
The Secure Digital (SD) memory card has a write-protect switch on the card case. Like the write-protect switch on a floppy disk, the SD switch prevents the card from being written to. (The SD card is slightly thicker than the MultiMedia [MMC] card.)
Moving the write-protect switch will allow you to write to and format the SD card. If you are looking at the front of the card, the switch is on the upper-left side.
