Question about Water Sport
How to listen to channels for uniden bc345crs scanner with useing frequency numbers
2 Suggested Answers
SOURCE:
SOURCE: uniden hand held scanner
How do you changen the frequency?
Posted on Sep 21, 2008
I recently purchased a Uniden bc345crs scanner. I programed 5 codes, but it will only scan one of the codes continuously. What do I need to do to have it scan the other programs? Thanks
Make sure you do have frequencys stored. Turn it on, push button to clock, then press bitton to scanner, then press hold, then the channel # you want it in, press hold again, now press e, enter frequency, press e again, if you want more channels press up, press e. Do this until channels are full or what you want. Then press scan if radio is ok it should scan.
Jan 24, 2015 | Uniden Radio Communications
I can't get local police on my uniden bc345crs
That's because many police departments use a baud rate (similar to old fax modems) to decrypt the voice and then put it back together again with the right encryption key
Nov 28, 2013 | Uniden Bearcat BC345CRS Police Scanner
Want to know the steps to programing
To program a known frequency:
- Power the scanner ON.
- Press the HOLD key.
- Enter the number of the channel that you wish to program.
- Press the FUNC and PGM keys.
- Use the keyboard number keys to enter the frequency, including the decimal point.
- Press the E key to set your frequency into memory.
More detailed programming instructions are in the manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of ac tie frequencies in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Jan 23, 2011 | Uniden BC72XLT Handheld Scanner
How to clear old codes of a scanner
I don't know of any global RESET function for your model scanner, but you can clear/delete the frequency (they're not codes) in any channel by programming 0 (zero) into the channel. Also, programming any new frequency into a channel automatically deletes/overwrites the previously programmed frequency.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B.
Jan 01, 2011 | Uniden BC248CLT Base Scanner
How to delete channels on the bc80xlt scanner
You can temporarily lock out a frequency by pressing the L/O key while the frequency is displayed, or can delete it by programming 0.0 (zero point zero) into the channel. Also, programming a new frequency into the channel will automatically delete/override the old frequency.
http://www.uniden.com/pdf/BC80XLTom.pdf
Bill B.
Dec 16, 2010 | Uniden BC80XLT Handheld Scanner
I have reset my uniden bc scanner and am trying to re porgram frequencies in i press hold, put in frequency number , press func. and then prgm. and it keeps telling me error. What could be wrong?
First, be sure that the frequency that you're trying to enter is withjin the scanner's tuning range. The ERROR message will appear if you enter an invalid frequency.
Second, follow this sequence to program a known frequency:
- Press HOLD.
- Enter the number of the channel you wish to program.
- Press the Func and Pgm keys (channel number will display).
- Enter the frequency, including the decimal point.
- Press E to enter your information into the scanner's memory.
Need the owners manual for your scanner? You can download and print it, at no cost, here:
For a comprehensive database of active frequencies in your area, visit:
Bill B.
Dec 08, 2010 | Uniden BC72XLT Handheld Scanner
How to remove a noisey scanner programmed number
For a temporary fix just press the LOCKOUT key while the scanner is stopped on the noisy channel. For a more permanent fix you can program 000.0000 into the channel, effectively deleting the programmed frequency from the scanner's memory.
http://www.uniden.com/pdf/BC244CLTom.pdf
Bill B.
Nov 14, 2010 | Uniden BC244CLT Base Scanner
How do you program a certain frequenceny and then make it the only one being monitered
To program a frequency into the scanner:
- Press the FUNC and PGM keys. The channel number will display.
- Press E to store the information in the scanner.
To monitor a single frequency:
- Press HOLD.
- Enter the channel number of the frequency.
- Press HOLD again.
http://www.uniden.com/pdf/BC92XLTom.pdf
Bill B.
Nov 14, 2010 | Uniden BC92XLT Handheld Scanner
Please tell me how to program in my county scanner frequency numbers .
To enter a known frequency into your BC92XLT:
- Enter the number of the channel that you wish to program (1 through 200)
- Enter the frequency, including decimal point (e.g., 155.455)
- Press E to enter the frequency into the scanner's memory.
More detailed programming instructions can be found in the factory user's manual which you can download and print, at no cost, here:
Bill B.
Oct 08, 2010 | Uniden BC92XLT Handheld Scanner
How do I program my Uniden BC72XLT race scanner?
1. Press HOLD. Then enter the channel number
where you want to store a frequency, then press
FUNC and PGM. The channel number appears.
2. Use the number keys and to enter the
frequency (including the decimal point) you want
to store.
3. Press E to store the frequency into the channel.
Notes:
• If you entered an invalid frequency in Step 2,
ERROR appears and the scanner beeps three
times. Enter a valid frequency.
• The scanner automatically rounds the entered
number to the nearest valid frequency.
For example, if you enter 151.473 (MHz), your
scanner accepts it as 151.475.
Need the manual for your scanner? You can download/print it here:
Nov 02, 2009 | Uniden BC72XLT Handheld Scanner
Water Sport Logo
525 people viewed this question
Top Water Sport Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
