SOURCE: Kenmore Oven and Broiler stopped working
My first suggestion is to remove the broil and the bake elements from the oven (unplug it or shut off the breaker) and test them with a meter on the OHM setting and see if you have continuity. You can't always tell if they are blown just by looking at them. Secondly, if they both check out alright, I would be looking at the ERC - electronic clock - you have a burnt relay in which case you will need a new one. Depending on where you are you may be able to find a place where it can be rebuilt for about 1/2 the cost of a new one. Hope this helps you.
SOURCE: Stove was on bake set to 350. Only the broiler
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*$%
Testimonial: "Thanks for the quality information and advice. Gave me the options and answers I needed to get this fixed!"
