Sony Bravia KDL-46Z4100 46 in. LCD HDTV Logo
Kalin Ivanov Posted on Oct 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sony Bravia picture turns green.
The screen turns green and the menus on the screen are distorted too.
Steven Wander
Level 3:
  • Master 599 Answers
  • Posted on Oct 03, 2015
Steven Wander
Master
Level 3:
Answers
599
Questions
Helped
286542
Points
1337
Check cable, if its using an HDMI, replace it: if component RGB cable, reseat or replace.
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
2helpful
1helpful
Bravia problems sony tv
Just visit the site given below. It has screen shots to defective Sony Bravia. Compare it to that of your TVs' and make sure about the fault. In most cases, the fault you described here sill be repairable.
Sony bravia kdl 52w3000 picture adjustment. The picture is too bug for the screen. I cant figure out how to shrink it.
I have a different Sony, but I think they all work the same. Go to menus (Press Home) Then select "Settings" and select "Screen Settings". Set Wide Mode to "full", Auto Wide to "off" , Auto Display Area to "off", Display Area to "normal". I hope this works for you
Bottom half of Sony Bravia TV screen has color distortion
Check for loose contacts in power outlet, RC cable, jack and socket.
In order to ensure, it is not caused by the input device, connect a DVD player and see.
3helpful
My sony bravia screen turned green I do I fix it?
When the color of the screen is complete green, you should not worry. That is the normal color that should be on the screen when no program is coming in because the cable box is off. So simply press OK on the remote of your digital box and your will see picture on your TV. If none appeared, then there is problem on your cable box. Call then your service provider.
4helpful
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
1helpful
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
