Exercise & Fitness Logo
T
Tina Posted on Oct 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It's making squeaky noises and the area where the long bolt where the handles are seem to have loose washers how do it get it loose to put on new washers because it won't unscrew.
Richard Warren
Level 3:
Genius:
  • Master 2,548 Answers
  • Posted on Oct 04, 2015
Richard Warren
Master
Level 3:
Genius:
Answers
2548
Questions
Helped
640153
Points
6606
Try soaking them with WD 40 and spray where the squeaky noise is coming from with it ,might be just be dry and in need of lube.
2helpful
2answers
My 2015 Nissan Versa is making squeaky sound while driving
A squeaky sound coming from underneath your 2015 Nissan Versa Note, even with low mileage, can be worrisome. While it's difficult to pinpoint the exact problem without a physical inspection, I can suggest some potential causes based on your description and the symptoms:
Possible reasons:
Worn suspension bushings: These rubber parts connect various suspension components and can dry out or develop cracks over time, resulting in squeaking when they move.
Loose sway bar links: These control bars aid in stabilizing your car during turns and can become loose, leading to clunking or squeaking noises.
Loose or worn-out serpentine belt: This belt drives various accessories such as the alternator and power steering pump. When it's worn or loose, it can produce a squealing sound, particularly when starting or accelerating.
Dry or worn CV axle boots: These rubber boots protect the CV joints that transfer power to the wheels. If they are dry or torn, they can cause squeaking, especially during turns.
Additional information for diagnosis:
Does the squeaking occur consistently or intermittently?
Does the sound change in pitch or intensity when turning or braking?
Is there any noticeable vibration or pulling to one side while driving?
Have you observed any other changes in the car's handling or performance?
Recommendations:
Schedule a service appointment with a qualified mechanic: They can examine the suspension, brakes, and other potential sources of the noise and provide an accurate diagnosis.
Do not disregard the noise: Ignoring it could lead to more serious issues and costly repairs later on.
Gather any additional information you can: If the noise seems to occur under specific conditions, make a note of them to assist the mechanic in their diagnosis.
While your low mileage may suggest that the issue isn't significant, it's always best to have it checked by a professional. Early detection and repair can save you time, money, and potential safety risks in the future.
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
3helpful
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
I bought a candy washer 2 days ago and when it spins it bounces around n is very loud. also it makes a squeaky noise when drum turns as if the seal is to tight against the drum, please help . sal.
Make sure the shipping bolts have been removed, and make sure there is no polystyrene packing that needs to be removed.
Make sure the washer is absolutely level as well.
If all else fails, then I would recommend you contact the supplier, and relate the problem to them, more so as it is a new washer.
Hope this helps.
Trot bilt rear self-propelled lawn mower, squeaky wheels even after lubricating with oil
Check the front axle, where it mounts to the frame. Spray the channel with white lithium grease (auto parts supply, W/Mart). My axel has a single bolt that holds it to the frame, and will make noise if I don't keep it lubed, especially in the area of the bolt. Hope this helps!
Regards, --W/D--
Jul 11, 2009 • Troy Garden
Nextra7 condenser dryer making squeaky noises
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
tukuymhg
5answers
GLTR1679 WASHER MAKES BANGING NOISE ON SPIN CYCLE.
Check the strut assembly. also a bad bearing can make banging noise.
My Hotpoint washer dryer WD865 moves around the room making loud noises when on a fast spin? The internal drum seems more loose than normal?
I had the same problem. You can open the top lid (2 screws at the back and then lift) The weight which is on top is secured by three bolts, all three of them were loose so weight was going from one side to another which made a terrible noise. Tightened the bolts and noise was gone!
Dryer still not working though.....
1helpful
Washer problem
If it makes a squeaky sound the belt could be loose or worn or wearing out. It it leaks out the bottom it could be a worn out or loose hose, or a leaky seal. The hose is easy. The seal is difficult.
Top Area Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Area Exercise and Fitnes Expert? Answer questions, earn points and help others
