Everytime i try downloading fotos from my camara to computer i have to install driver
Forget about drivers for your computer. Buy an inexpensive (under $20) USB SD flash memory card reader and connect it to your USB port. Remove the SD memory card from your camera and insert it in the card reader. Open Finder if you have a Mac or My Computer for a PC. You will see your memory displayed just as if it were an external hard drive. Open the files on the SD card and copy them to a file on your hard drive. It is that simple. Professionals use this method. We almost never download directly from the camera.
SOURCE: Nikon coolpix L11
well have you got a card reader? if you have then plug the memory card into the wright socket and see what happens
SOURCE: Nikon Coolpix driver for Win98
Ugh. Nevermind. I knew as soon as I posted this, I'd figure it out! Since I've been seeing this same question floating around in search engines, might as well post it, I guess. Who knows, maybe save someone a headache.
- Install the Nikon drivers from the yellow disc labeled Picture Project:
Choose "custom installation", uncheck everything except the very top box labeled "driver." (Despite what Nikon's booklet says, Picture Project DOES NOT have to be installed to make the camera work). After they are installed, you will be prompted to restart your computer.
- After restart, hook the camera to the computer via the USB cable and turn the camera on. Windows will now detect a new device and launch the add new hardware wizard. Select "display a list of all drivers" and click next.
- Now check "show all hardware" at the bottom of the window, and select the category "hard disc controllers" from the left-hand menu.
- Scroll down this menu until you find "Nikon Corporation." Now in the right window you will see "Nikon Digital camera Controller." Click next.
- The drivers should install with no problems and no more work to do. Your camera is now compatible with Windows 98! If installed correctly, the window should look like this:
- If you go to My Computer, there will be a new icon labeled "Removable Disc." Click on it, and you'll notice all your photos are stored here in a folder labeled NIKON100.
Notes:
I'm not sure, but this setup should work for the following Nikon models listed on the official site as well:
COOLPIX 2000 / 2100 / 2200 /
2500 / 3100 / 3200 / 3500 / 3700 / 4100 / 4200 / 4300 / 4500 / 4600 /
4800 / 5000 / 5200 / 5400 / 5600 / 5700 / 5900 / 775 / 7600 / 7900 /
8400 / 8700 / 8800 / 885 / 995 / L1 / L101 / L2 / L3 / L4 / L5 / L6
/L10 / L11 / L12 / L14/ L15 / P1 / P2 / P3 / P4 / P50 / P5000 / P5100 /
S1 / S2 / S3 / S4 / S5 / S6 / S7c / S9 / S10 / S50 / S50c / S51 / S51c
/S200 / S500 / S510/ S700 /SQD1 / D1H / D1X / D100 / D2H / D2Hs / D2X / D2Xs / D200 / D40 / D40x / D50 / D70 / D70s / D80
If you don't have the Picture Project disc, you can download the same drivers from the European website (the link in the above post). The correct driver for the Coolpix is located in Drivers > Clpx > EN > Setup.exe (for English setup).
Before attaching the camera, be sure it's set to Mass Storage.
(Menu > Set Up > Interface> USB) There should be a V-shaped checkmark next to the Mass Storage option.
SOURCE: can't uplaod my pictures
try uploading your pictures using your friend's similar datacable.. if you are able to do it then the problem lies with your cable.replace it. if the computer still doesnt recognize your camera try using a memory card reader and you can easily upload your pictures through it.. hope your problem is tackled. thanks for using fixya!. please dont forget to rate my solution.
SOURCE: Computer cant find USB drivers for Nikon d40
I had the same problem with my D40x - I changed my USB cable to a much more robust one and all my problems went away.
You shouldn't need a driver, most OS's will recognise it as an imaging device.
SOURCE: how to remove the battery from nikon d3000
the little trap door on the bottom houses both the memory card and the battery. you have to push the battery slightly to release it. i fond the easiest way at that point is to tip the camera and the battery usually slides right out.
