Bolens 13.5 HP Manual 38-in Riding Lawn Mower with Briggs & Stratton E Logo
C
Charlie Worsley Posted on Oct 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you replace the PTO cable on a Bolens tractor?
txslim55
Level 3:
  • Master 1,104 Answers
  • Posted on Oct 03, 2015
txslim55
Master
Level 3:
Answers
1104
Questions
Helped
409417
Points
5454
The pto cable on our White lawn tractor has broken 4 times in the past 2 years...help
Either a very poor quality replacement cable or there is something binding causing you to out too much stress on the cable. The pto should be relatively easy to engage if bit there us a problem with it.
Jul 27, 2016 • Garden
My riding lawnmower engine dies everytime i release the brake pedal
Id say that even though you say the operator seat switch "looks" ok the symptom you describe is a perfect match to a defective seat switch and or wiring
Nov 09, 2015 • Garden
Replace cable
how about a model number. helps up see what kind of PTO engagement system you have... but if it's the upside down J you have to points. one on the deck and one under the dash. find both of those and you should be able to see what to do next
I have a Bolens Model 13AM762F765 38inch cut 15.5 HP twin blade lawn tractor. It runs like a champ as long as I do not engage the blades or put it in reverse. It will stall if either of these two things...
Sounds like a safety switch. Just as there is a safety switch under the seat that shuts mower off if you get off seat while engine is running, theres also safety switches for, pto, drive, reverse, etc. I would get a multimeter and look for switches under chassis and test with meter for continuity.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 08, 2013 • Mtd Garden
2helpful
2answers
Pto won't engage
Sounds like you need a new mower drive belt.
Feb 02, 2013 • Garden
2answers
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
I have a bolens 38 inch riding mower. The cable that engages and disengages the blades seems to be stretched. The blades spin all the time. What needs to be done.
I have that problem also.. yet my cable is stretched and came undone, so Im looking for one to replace that old one.... the reason the blades still spin is because of the stretched cable, replace it and the blades will do correctly..mine has actually unwravled, about to break so it easliy slipped out if the hole it sticks in.on the lever bottom not the deck, thats usally where the wearing begins..because of working the pto lever so much..I actually, until I can buy noher, tooka light cage wire and wrapped around the area broken, unwravled. and retied the other end around the area where the lever hole is.. it actually tightend it up , now my blade runs correct..long story ha..but u need a cable...thats it. cost 10 bucks..aprox..
Top Bolens Garden Experts
Jay Finke
Jay Finke
john h
Are you a Bolens Garden Expert? Answer questions, earn points and help others
