Got some bad news for you https://www.justanswer.com/electronics/8xu1d-possible-change-language-kenwood-mdv-313.html
My kenwood mdv-313 does this and does not allow me to remove this gps icon on the home screen and because of that it does not do anything, it will not shutdown unless i turns the car off
You need to find settings = ??
language = ??
english = ???Inggeris
there is no manual to convert to english as it was made for the japan market it may not even have english or western languages installed. you would need to see if its updatable but disc or not but to do that you would need to speak to kenwood to see if there is an up date. the model number will be different for western areas of the world.
SOURCE: Chaging the language to English
turn on the camera, then go on menu right?
go to setup, then scroll down until you see language on the right side.then click on the right arrow (to highlight 'language'),and click on in once again to change te language, click on english, and wahhla!9 oh, and i 'think' click on ok after that. :)
SOURCE: LANGUAGE SETTING JAPANESE TO ENGLISH
Hello analyn
There may be a simple fix to this problem.
Find a friend that has a cybershot of the same model as your own. In their camera, open the menu and navigate to the language setting. While you do this count how many times you press the button. Example:
Menu
-camera settings 1
-program 2
-personal settings 3 press ok
personal settings
-storage type 1
-date and time 2
-language 3 press ok
language
-spanish 1
-english 2 press ok
-japanese
Although the language is different, the number of spaces should be the same, so even though you can't read it to change the language, you should be able to count it out. Or if you are lucky you may have a Japanese friend who can read it.
Hope this helps
-Chris
SOURCE: request for the english langage
Hello sir i have fujifilm finepix 4500 digital camera how i can english in english language
SOURCE: How to switch language on japanese bought sony dsc-wx1 cybershot?
I bought a camera in Japan (Sony Cybershot DSC-WX1) and now it seems that i can't change the language from japanese to english. If i select (can't read it but with the help of the english digital guide i think i have the right menu)change language, there seems to be only one language available. -japanese- How do I solve this?
SOURCE: My question: I bout a
The language setting is the last option on the setup menu. Press menu, then right side of the rocker for setup, then up for language, then right to set and up or down to select English, then menu to exit.
