Mine does the same when I try to start it on low. If I start it on hi after it gets going I then can turn it to low and works great. Hope this helps.Also you need to take it apart once a year , remove blades, take it outside and air blow the motor out .
A short circuit in the power wiring would probably cause the fuse or breaker controlling the circuit to open. Make sure the AC outlet you're plugged in to is actually working. If so, there's an open circuit somewhere if no power is reaching the motor.
Have you checked the switch with an ohmmeter to make sure it's really working? Check the wiring from the switch to the motor. You can also make sure the motor windings aren't open with the ohmmeter. The motor may have burned out as they sometimes do.
Check for voltage right at the motor. If this is a brush-type motor, the brushes may be worn out. It may also be that the motor is getting voltage but has a bad starting capacitor. Most commercial equipment uses capacitor-start motors, and the capacitor is usually mounted in a bracket on the motor. You can test the cap with a meter that has capacitor checking; replace the cap if it measures outside of the tolerance marked.
