Troy-Bilt Troybilt Horse 6, 7 And 8 Hp Tiller Reverse Disc Logo
Jackie Coulson Clements Posted on Oct 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking tine shaft - Troy-Bilt Troybilt Horse 6, 7 And 8 Hp Tiller Reverse Disc
ROD GANDY
Level 3:
  • Master 1,602 Answers
  • Posted on Oct 02, 2015
ROD GANDY
Master
Level 3:
Answers
1602
Questions
0
Helped
591307
Points
4916
Your seal on the shaft defective,
www.ask.com/mfg.name/make/model/service/parts/leaking/tine/shaft/
How do I change the tines
You have not shared which model and make of tiller you have, but many of them have a set screw or two holding each tine on.
You would need to loosen the screws, and maybe polish the shaft with sandpaper and oil it to get each tine off in order.
Some tillers use a different method of tine installation, since this can be patented or trademarked.
For example, some have the tines permanently attached to the shaft, so the whole shaft must be replaced as a unit.
God bless your efforts.
May 12, 2016 • Garden
1helpful
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
The rear tine seals are leaking ive taken the bolts out but the tines will not come off what can i do
You could try putting the tiller to use, preferably where it will have to work hard to till the ground it unsuccessful you may need a torch and some good old fashion luck to loosen tines from shaft. Now consider this; if the bearings are worn so that the shaft is loose new seals will not hold up and you will risk doing further damage to the worm gear located on rear shaft and possibly other damage to your transmission from contaminated oil.
The oil seal where the tiller attachment fastens to the tiller is leaking how do i remove the seal
IF THIS IS A WALK BEHIND TILLER OR FRONT TINE TILLER. THERE SHOULD BE PINS OR BOLTS HOLDING THE TINES ON THE DRIVE SHAFT REMOVE THESE AND PULL THE TINES OFF THE TILLER. THEY MAY GIVE YOU A HARD TIME GETTING THEM OFF SO DON'T GIVE UP. ONCE YOU GET THE TINES OFF YOU SHOULD SEE THE SEALS YOU CAN POP THE OLD ONES OUT WITH A SCREW DRIVER CLEAN OUT THE SOCKETS WHERE THE NEW SEALS WILL GO REPLACE THE NEW SEALS GENTLY WITH A SMALL HAMMER TAPPING THEM IN EVENLY AND TRY NOT TO BEND THE SEAL
Feb 05, 2011 • Garden
16helpful
2answers
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
1helpful
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Top Troy-Bilt Heavy Machinery Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
