SOURCE: not sure of u-line ice maker part number for a BCM45A
Supco makes a generic replacement carried by most good Appliance Parts Stores.
SOURCE: I have an old U-line ice maker. I can not find
The mechanical parts of those models is the same as a BI 95 or BI98. If your looking for the faceplate that would be part number 150. This includes the timer motor,gears,water switch, and hold switch. You can order this thru a parts distributor. Appliance Parts Depot or All Brand Parts should be able to help. If you want to replace the complete icemaker assemly that part number is 402
SOURCE: Can the refg.be re-wired?
U-lines needs the icemaker to work properly. By doing what you did you would void all warranty. The controls are in the icemaker so the original parts would not work the way you want it to.
SOURCE: wiring
wiring diagram is on the back of the machine. If you have clear ice maker it may be on the back of the front plate.
SOURCE: wiring digram for under counter uline ice maker
It is on the back of the machine, if you have clear ice maker, it may be on the back of the front plate.
