I use an A200 at work, and when switching speeds, the handle/lever snap to each speed, whereas on my N50, you can feel the lever slowly, manually moving something in the machine, and feel a click when it gets in the next gear, at which point the handle has some give to it, and can jiggle easily. On the a200, the handle is pretty much stuck in the position of whatever speed you are in, and clicks/snaps into the next gear when moved over. Is this normal?
SOURCE: Hobart A200
amy, depending on how old your mixer is there are 2 types of clutches for 1st gear.these could be your problems--a key is sheared on the shaft--shaft/gear is broken.the bottom part of the mixer where you put on the attachements is called the planetary,does it look like it has moved down?you could tell if the dough hook,wire whip,ect,ect is hitting the bottom of the bowl.if this is the case its just simply tightening the 2 nuts next to the beater shaft.if this is not the case you would have to dissasemble the transmission.let me know.
SOURCE: mixers eating brass gear driven by motor pinon
Thats called a sacraficial gear because its brass which is a soft metal.This gear takes most of the strain but i think either a spacer is missing or the gears arent meshing correctly.The transmission assembly the shaft next to it make sure all the spacers/washers are there.Goto hobartcorp.com you will find an exploded parts breakdown.
SOURCE: Hobart A200
When you say lag and catch up. This may not be a issue. I have seen this with dough and a spiral hooks on all sizes of Hobarts the hook and dough get in a position to push the hook forward and the drive gears catch back up the hook. in fist gear on the 20 quart this is common for sure. but its normal. if you have a real slip from a sheared key it will not take long to where you can hold the planetary shaft with your hand and stop it. another slip that might be possible is if your mixer has the first generation worm shaft gear Assembly. when it is worn out it will slip you. this is the shaft that drives directly off the motor. you can tell if it's first Gen by it has a large spring on it. the tow later versions are all keyed to the shaft no chance to slip unless a key shears.
Michael
SOURCE: 3rd gear spends at 1st gear speed with clicking noise
A key is most likley sheared on the center shaft.Take the gears off the center shaft.
SOURCE: A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
