How do I set line 3 as automatic dial tone when the handle set is picked up?
SOURCE: No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
SOURCE: How do I change the default line on our phones
restore the factory settings of your mobile byentering the security code of mobile.
SOURCE: M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
SOURCE: 3rd line - no ring tone on one of a 3 set phone system
Yes, as you noticed FEATURE *6 only changes the ring tone on the set...
You have to go into system programming to make this change...
-> First you need to know the extension on the set, you can find this by doing FEATURE *0 and press the Intercom button.
-> Get into programming and you'll see TERMINALS&SETS and enter
-> type in extension that is giving you problems
-> hit next till you see LINE ACCESS and enter
-> the you'll see LINE ASSIGNMENT and enter
-> type in the line 003
-> and press change to APPR&RING
-> hit next and RLS to back out of programming
SOURCE: When I pick up the handset on my M7208, it goes to
The dead line needs to be taken out of the line pool soyou can grab the right line.First you need to know the line number that you need to take out of the pool.
thats done by entering feature *0 and pressing the line button for the dead line. the screen should say
L025: line 005 (the L025 is the important part).
Write it down for later.
Next you need to get into system programming.
Programming is done on M7310, M7324 and T7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key(bottom right arrow).
the display should say LINES
press the show key (top right arrow)
the display should ask for a line number (001-004, 025-028 *thats lines 5-8) enter line that you want to take out of the pool group and press show (top right arrow)
the display should say trunk/line use
display should say line type:pool A
press the change key until it says public
press the heading button(top left arrow) til it says lines again
repeat procedure for next line/lines
press the release key when finished
it grabs the right line.
