Question about NorStar Lands Phones
HOW DO I TELL WHAT MY PHONE EXTENSION IS? - NorStar Lands Phones
  • NorStar Master
  • 5,631 Answers
Ask the central.
If there is no operator, ask someone push extensions till yours start ringing
Posted on Sep 30, 2015
SOURCE:
The display went out on my lucent phone
If the extension still works then the LCD display has gone out. Replace the phone. If the extension doesn't work then move the extension wiring to a different port on the system. This will tell you if the port has gone bad.
May 22, 2014 | Avaya 700340193 Corded Phone
When i transfer to another extension, the call is automatic in speaker phone, why?
The handset has been programmed to auto answer all or some calls. You will need to change it to normal answer mode via EXTN 20/21 whichever is your programming extension. To tell which one is your default extension it is usually the extension that will still work as a normal telephone in the event of a mains power failure.
Aug 26, 2013 | Panasonic KX-T7730 Corded Phone
How do I change the current extension on my polycom 301 phone from 334 to 300?
Go to support on the new phones manufacturers web site and you can download an owners manual, which will tell you how to re-program the phones extension. murf427
Aug 01, 2012 | Polycom IP 301 SIP IP Phone
Programming an extension
Of course not. That's what the USER manual is for It's filled with step by step instructions for programming your phone. Some of the programs are set up at installation, some are user programs.
Carl.
Jul 12, 2012 | Panasonic KX-T7633 Corded Phone
How to change phone extentsions
You are basically setting up what extension teh phone is to use. Now you need to tell teh extension what user is going to use it.
If the phone says, no user, then there should be a login button. If there is not, contact the admin person so they can program one.
May 04, 2012 | Avaya 5610sw IP Phone
I added new line at Norhern Telecom Meridian System but line is not shown on my M7310. How to add line on phone
First press feature *0 then the intercom button this will tell you the extension number. write this down.
Press feature **266344
then 266344
should now say terminals and sets on the phone.
press 1st lit arrow on the left side of phone
enter extension number or press find and enter extension number.
press the top arrow on left side of phone until you see line assignment
press list
when you get to the new line press change until the line says appear only(no ring) or appear and ring(rings on the phone)
press rls when done
Jan 11, 2011 | NorStar M7310 Corded Phone
Not in service
Whoops, the second part of that is press FEATURE *0 and the intercom button before you move it and see what extension it is.
Do the same thing after you move it. It will tell you what extension it is and if it stayed the same.
The system CoOrdinator or installer can turn off that Auto Set Relocation feature :-)
Carl
Sep 17, 2009 | NorStar Lands Phones
Finding the extension number
press feature *0. you can now look at any button on your phone to see what it is, touching the intercom button will tell you your extension
Aug 18, 2009 | NorStar M7208 Corded Phone
Taking the call from the extension
Try *41 followed by extension number
OR *40 followed by group number eg 00 or 01
Jan 07, 2008 | Panasonic KX-T7630 Corded Phone
Extension Name
so,first find out what is the port of this 106. by go to 106.it has to be a display phone.press feature then 4. it probably show 106 tel 07. so your ext port is 07. go to any display phone. press feature #0*8974.show program mode.now press line 4 then number 18.show 01/18. name of ext.now you press **** 4 times then press 07.show 07/18 sta name.now you can use the key pad to enter mat.press hold to deleted any digit.agter you done press TRF then speaker to exit. good luck.
Sep 20, 2007 | NEC DTU 8-1 Corded Phone
Lands Phones Logo
47 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
