Hello. From what you're describing, it sounds like the user interface board(fancy name for control panel) is defective. The part number for it is W10215814 and is #9 on the Pic 1 exploded parts diagram. The sequential pics show the procedure for entering diagnostic mode, interpreting error codes, clearing codes, and testing different parts of the dryer. I hope I helped you!
Top 364 Complaints and Reviews about Amana Appliances
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.3 - 49 votes
I bought a new Amana washer and dryer set for my home. ... so I called them and theycan't help me - only if I buy another warranty for now 414.00. ... If the part has beenchanged or modified then it seems Amana is aware of the problem.
or try Consumer Reports.
SOURCE: Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
SOURCE: My dryer wont heat up...It just blows cold air....?????
It may be the thermal fuse but it could also be the heating element. The way to check is to open it up as described above and run the dryer. Watch the element and if it turns on then off again immediately then it is your thermal fuse. That is only about 15 dollars to fix and you can get a new fuse at any appliance repair shop. If the element doesn't ever come on then the element is burnt out and needs to be replaced. This is a little more expensive. I hope this was helpful and if you have any more questions feel free to ask me. Good luck.
SOURCE: kenmore dryer will not dry completelt in even heat cycle
This video will help you to determined what you need,
copy n paste
http://www.youtube.com/watch?v=HRKIU4LiS20&feature=related
for parts n prices
http://www.partselect.com/AppliancePartList.aspx?Brand=Kenmore&Appliance=Dryer&ModelNum=&Type=Electrical%20Parts,%20%20No%20Heating%20Elements&MinSize=U&MaxSize=U&Electrical=Y&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Was this helpful?
SOURCE: Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
