Centric 2002 Chevy Suburban - 1500, rear disc brakes, with limited slip axle - Premium Rotors Logo
Jessi Carman Posted on Sep 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove rear axle out of 2002 suberben - Centric 2002 Chevy Suburban - 1500, rear disc brakes, with limited slip axle - Premium Rotors
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245527
Points
21965
2002 Chevy S10 2wd Rear Axle repair - what do I have to do to remove the carrier bearing?
In general you have to drain the rear end, remove the cover, remove the carrier pin, remove the axles, then remove the carrier from the main shaft and replace the bearings.
How do you remove rear axle on 97 chevy sub
Remove the rear cover then remove the 5/16 bolt that holds the 3/4 inch diameter steel pin in then push the pin out.Now push the axle inward and take a pair of needle nose pliers and pull the c clip out then you can pull the axle out.
2helpful
2002 ford explorer rear axle removal
YOU NEED TO LET GARAGE FIX BECAUSE YOU NEED A PRESS TO PRESS WHEEL BEARING OFF THE AXLE SHAFT.
1helpful
How do i remove the drivers rear axle in a 2002 chevy avalanche
you will need to remove differential cover. drain out old fluid first! rotate the axle so you can get to the cross pin, and remove it by undoing a bolt that holds it in place. be careful to not let cross pin get lodged where you can not extract it ! the axles are held in by a c-clip on each one. then slid axle out. you may need to push on outer end of axle to release the c-clips. good-day !
6helpful
2002 jeep grand cherekee rear axle seal removel do i need to remove c clips in rear to remove axle
No.....after removing the brake caliper and rotor, Unbolt the axle retainer plate from the axle tube flange. You need a slide hammer to pull the axle out.
Need to remove rear axle to replace bearing
Open the rear diff cover you will see what is holding the axle in place.
7helpful
2answers
Replace rear wheel bearing 2002 ford explorer 4x4
you must remove brakes, then remove axle nut, then remove upper control arm and finally tie rod stabilizer, remove axle from car then bearing can be accessed. this is a difficult job that requires special tools so be careful
2helpful
Rear Axel Seal
Wheel, brakes etc that are in way of pulling axle out have to come off. Drain rear end fluid, remove rear housing cover, remove bolt that holds pin in differential, remove differential pin, push in slightly on axle to remove "U" clip that holds shaft in, then slide shaft out. replace seal. Reverse procedure for re-install & fill with gear lube. If any questions, get back to us.
3helpful
Leaking rear axel seal
  1. Remove or disconnect the following:
    Rear wheel Brake caliper and rotor, if equipped Brake drum, if equipped Axle retainer nuts Axle shaft, seal and bearing assembly
  2. Split the bearing retainer with a chisel and remove the retainer ring.
  3. Press the bearing off the axle shaft.
  4. Remove the axle seal and retaining plate.
0900c15280220349.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Rear axle seal and bearing components-2002-05 exc. 2005 Grand Cherokee Hope this helps, please dont forget to rate my solution.
Lefty64
14helpful
2answers
Can not remove rear axle on chevy avalanche 4x4 1500.
you will need to take off the differential cover (drain and change diff oil at this time)
rotate the axle so that you can get at the cross pin and remove it by undoing a small bolt that holds it in place. it should slide out with ease, but i have had them stick, take care not to let the cross pin get lodged where it is difficult to extract
a single C-clip is holding each axle inside the differential housing
you will need to push in from the outer end of the axle, while simultaneously manipulating the C-clip off of the inner axle, repeat this same process on the other side
i will put some of pics up in a minute
Top Centric Wine & Spirits Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Don A
Don A
Are you a Centric Wine and Spirit Expert? Answer questions, earn points and help others
