SOURCE: bidet doesn't work
sounds like you have air in the lines. Try turning on the bidet then shutting off the water to the bidet at water cutoff then turning the water back on all while the water valve on the bidet is turned on. this might fix the problem. good luck and let me know
SOURCE: The water is not getting hot anymore. How can I fix this problem?
I'm not sure what exactly you're talking about here, but if it's a hot water heater, the most common problem is that one or more (most have two) of your heating elements have burned out. You'll need to get new elements for one or both of them and install them. CAUTION: Turn off the power on whatever circuit handles the water heater, get yourself a water heater element wrench (nothing else will do the job), cut the water supply to your home - all of it! Remove the defunct element(s), replace it or them, turn the water supply back on and listen - put your ear up against the tank and see if you can hear a sizzling sound. After about an hour you should have hot water again.
