Inverter KEB COMBIVERT F5 Logo
k
kunal Posted on Sep 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does OL2 fault in KEB drive indicate? - Inverter KEB COMBIVERT F5
mntech1
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Inverter Expert 120 Answers
  • Posted on Jul 25, 2016
mntech1
Inverter Expert
Level 2:
Mentor:
New Friend:
Answers
120
Questions
0
Helped
78111
Points
185
Too much current is being required with the motor shaft not rotating. This is most likely a parameter adjustment issue with the motor data, torque limits and protective functions.
Possible motor issue as well.
tip
KEB COMBIVERT F5 help
When ever you have a questions about a KEB Combivert inverter, it is best to provide as much information as possible. At a minimum provide the following:
Part# or art-nr
Serial # or ser-nr
Fault codes
Type of machine
Machine manufacture
Problem description
KEB manufactures many different types of F5 inverters and each type has different hardware, software and functionality. With the above information it is easier to provide a better solution to the problem.
I have a Keb Inverter and it's showing negative reading while on standby
Contact them direct. They will be interested to hear this. Did you check polarity with a test meter?
https://www.google.com/search?q=keb+inverter+reverse+fault
KEB Inverter - Contact Our Responsive Team
Ad·https://www.kebamerica.com/
KEB America Is a Top Manufacturer Of Industrial PCs, HMIs, VFDs, Clutches, Brakes, & More. The Future in Control & Automation Technology w/ Customizable Products - Contact Us Today! Since 1972. Responsive Support. Customizable Products. Automation Experts.
DrivesUp to 1,000Hp; 230 & 460V classes. High Performance
ContactReach Out to Our Responsive Team Expert in Customizability
Contact UsSales Quotes Technical Support
About UsThe Future in Control & Automation Made in USA
How can I reset the error E.OP from my F5 Combivert inverter?
I may miss the point here. If the question is how to clear the error, page 57, item 4.7 Error Messages, of the KEB instruction manual may be of use. https://www.manualslib.com/manual/1293218/Keb-Combivert-F5.html?page=55#manual
Here is information about the error code:
KEB Error "E. OP"
ERROR overpotential (voltage)
1 Voltage in the DC-link cicuit is too high.
Occurs if the DC-link circuit voltage exceeds the permisible value.
Causes:
- poor controller adjustment (overshooting)
- input voltage too high
- interference voltages at the input
- deceleration ramp to short
- braking resistor defective or too small
Given the very technical nature of the KEB, I lean toward referring to the manufacturer's support. There are quite a number of KEB YouTube videos and a number of supporting documentations available on the web. Perhaps the following will be of use if not an entire misdirection: https://www.kebamerica.com/elevator-support/
https://www.kebamerica.com/products/f5-inverter/
My KEB drive shows alarm "E.nOH" or "E.OH" or E.OH2, what does it mean?? How I will solve it. My motor and drive temperature is still normal but drive shows these alarm.
These are all messages that follow overheating. E.nOH indicates that the heat sink has returned to the normal temperature range and the unit can be reset. E. OH indicates that the power module is over-temperature. This could be caused by insufficient air flow at the heat sink. That is caused by dust/dirt. The ventilator could be clogged or the ambient temperature is too high. E. OH2 indicates that the motor protection relay was tripped. Check for dust/dirt and clean any filters. Make sure that nothing is blocking the air flow around the unit.
KEB uses these error mesages on the CombiVert F6, https://www.keb.de/fileadmin/media/Manuals/f5/control/f5m/00f5mebk320.pdf .
I hope this helps.
Vmi fault coming up
Vmi is not a KEB fault code.
Fault Epuc1
See "Inverter KEB COMBIVERT F5 Tips & How Tos"
Unit will need to be repaired or replaced.
Fault
at the first i want to know the error message appear after switch on the power on the drive with out any load or with load .
There is a fault invalid encoder inerface identifier in keb F4 solve he prob.....
Please provide part# of the unit in question and manufacture of machine.
Top Inverter Electronics - Others Experts
Ngoro
john h
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
