NorStar M7310 Corded Phone Logo
Customer service for Meridian phone systems
Cannot retrieve voice messages or page
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 14, 2008
SOURCE: remote access to voice mail
from a tt phone, after the message, hit * your ext # and then your pswrd.
it's just like retreiving your messages from an ext not your own.
from there you can change your access info in the admin section.
pause 5 secs and listen to the prompts from the vm syst itself.
Anonymous
  • Posted on Mar 18, 2008
SOURCE: Meridian M7310 phone system
We had a tech come in who has worked on the system a long time ago and he said because of the power surge it fried the Star Mini. He said they are hard to get and may have to search on Ebay. We only had a battery backup instead of a UPS.
So for now we are without voicemail.
A
Anonymous
  • Posted on Apr 30, 2008
SOURCE: Paging
have you tried feature 62 or feature 602, that worrks for me
Anonymous
  • 11896 Answers
  • Posted on Apr 15, 2009
SOURCE: I have a problem with
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
consultel1
george peters
  • 860 Answers
  • Posted on Oct 13, 2009
SOURCE: We have the Norstar Meridian (M7310)telephone
Could be two things, there could be a general delivery mailbox attached to the system which is mail box 100, or the new service provider has a off premisis voicemail attached to the lines. if there is VM on the lines you should get a stuttered dial tone on the line indicating that you have a voice mail.
I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
Question edited for clarity.
This phone system has two features.
Answerphone system which records messages to the unit.
and
Voice Mail System which is an extended (often paid) service from your telephone provider.
Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.
Page 32 refers
https://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdf
Retrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply.
Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically.
Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33
Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone.
How do i change the voicemail on my landline and how do i retrieve messages on telkom landline.
Hello, Janine -
The voice mail and message service for your landline phone is provided by your landline service provider. If you did not receive a printed booklet directions for your landline phone service, I suggest you call your landline telephone service provider Customer Service number (Telkom) and ask for one.
From the Telkom web site, this looks like the number to call:
10210
Best wishes
1helpful
We have a Vtech cordless phone and have been using the answering machine. We have never set up a voice mail with our phone service, but tonight when we came home the phone was flashing with "new voic
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
1helpful
Our phones have been working fine without incident for almost 5 years, as is.We no longer have the Administrative Switchboard, as our phone system was separated between two offices. This morning, with no...
Programming for the voice mail is done on M7310, M7324, or T7316e sets. Try finding one of these sets around the office to do the administrative programming.
Voice mail not working
The Voice Mail system provides the voice mail service based on the existing network. When a call is transferred to the VM system, the system asks the calling party to leave a message for the called party when the called party is busy, powered off, or out of the service area. It provides voice mail, call prompt, and voice short message and email. By adopting VM service, operators' system put-through rate, service usage rate, customer satisfaction, and revenue can be improved.
1helpful
My cordless phone model #16725 w/answering machine (old model) has a blinking lite with a message saying "new voice mail" How do I retrieve this message?
If theres a play, play message, or voice mail button on the base/main charger, try that.
Or maybe your phone service has its own voice mail, in which case, try dialing your own phone number.
1helpful
We have the Norstar Meridian (M7310)telephone system in our non-profit organization. Recently there was a change in our service providers and since that time we have had nothing but problems with our...
VOICE MAIL INACCESSABLE - PHONE JUST RINGS
Voice mail was down. Called a service tech.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
