Print Shop 20 is not completely compatible with Windows 7. For example, when I try to open a Print Shop 20 project on my Windows 7 computer, by double-clicking on the file which is displaying the Broderbund logo, I receive an error message which says, "There was a problem sending the command to the program." And, even though the Print Shop 20 file will eventually open, it actually opens in PrintMaster.
It is, however, possible to force the file to open in Print Shop 20 by doing this:
1. Open Windows Explorer, then find and right click on a Print Shop 20 *.sig file.
2. When the menu drops down, click on 'Open with...'.
3. When the 'Open with' window opens, make sure that there is a check mark in the box next to 'Always use the selected program to open this kind of file'.
4. If Print Shop 20 is displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on Print Shop 20, then click on OK.
If Print Shop 20 is NOT displayed in either the 'Recommended Programs' section or the 'Other Programs' section, click on the 'Browse' button.
5. When the second 'Open With' window opens, navigate to this folder
This should cause all *.sig files to automatically open in Print Shop 20 when you double-click on them. However, since file associations are always based on the file extension of the project file, it might be necessary to repeat the process above for all Print Shop 20 file extensions.
Solution You must reinstall Microsoft .net framework.
You can do this by: Go to the control panel Go to add remove program select Microsoft .netframework 1.1 and remove Also if you have the Microsoft .netframework 1.1 Hotfix select that and click remove as well.
Once both those are removed we can reinstall Microsoft .netframework from the Print Shop Install disc
You can do this by: Insert the Print Shop Install disc Double Click on My computer Right Click on the Drive that contains the Print Shop Disc Left click the open option. Double click on the folder called Setup Double click on the file that’s called 1033DotNetfx This will reinstall the net framework on your computer and it should fix the issue you are having.
TPS Window Appears on Print Shop® Splash Screen
Description
Solution
When attempting to open Print Shop® 20, a TPS window opens on the Print Shop® splash screen. The only option available in the small TPS window is to click OK. This issue occurs when Microsoft® .NET Framework 1.1 has been uninstalled. Reinstalling Microsoft® .NET Framework 1.1 will resolve this issue. View the remainder of this technical note for the instructions. Complete these steps:
Close all windows and programs and return to the desktop.
NOTE: If the TPS window is still open on the desktop, click OK. The Print Shop® splash screen will close.
Insert the Print Shop® 20 DVD or Install CD into the proper drive.
Double-click the My Computer icon. For Windows® XP, click Start and click My Computer.
Right-click the CD/DVD icon that represents the drive where the disc was placed and click Open. The contents of the disc will display.
Double-click the Setup folder.
Double-click 1033dotnetfx.exe. The installation of Microsoft® .NET Framework 1.1 will begin.
Review the License Agreement, click to place a dot by "I Accept" if the agreement is accepted and click Next.
Click Install to install the Microsoft .NET Framework 1.1.
When the "Installation of Microsoft .NET Framework 1.1 is complete" message appears on screen, click OK.
your lense is jammed try to put your finger in it and close the lense all the way it might me like hardly closed, i had that problem and now my is open all the way so i cant close it yuo can email me at [email protected] or im makaluso06
