If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
SOURCE: i have a toshiba 27a33
Hello
Sorry. Your TVs front panel has no menu button to press. The only way to chane it to AV/TV, cand be done with its remote control which ahs that button to press. You just buy one new remote control, of get the present one repaired. OK.
SOURCE: How do I switch to auxiliary mode on Toshiba TV Model 27A33 without the original remote?
look for a little button of the front to switch inputs, Toshiba is pretty good about putting those buttons on the tv
