Screen is black but sometimes picture comes for 1 second and goes back intermitently .
When i start tv , i got sound but no picture , i can see screen working ,screen is black lighted but without any picture , sometimes picture comes for 1 sec and goes back .
The tv that I have is an LG 42LB5600-UZ, but that wasn't one of the choices. The problem is that the television turns on... has a picture and sound, and then in about 30 seconds, the screen goes black but the sound continues. It is the same on every channel. It worked fine last night, but not today.
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG.
No display in monitor
Jan 11, 2013 Ps3 and hdmi cable
Oct 8, 2012 More results from ccm.net
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
I have the same TV and what is happing is the TV has 2 recievers in it to allow the PIP, So you have a power pack gone on 1 reciever the other is working, Your set has 2 power packs,1 for each receiver.
I had both of mine go, 150$ a piece to have fixed, good luck.
not worth fixing,techs charge at least 65.00 $ an hour not including trip charge.no easy fix. you can get new lcd flat panels for under 500$ now. especially at best buy,ther giving them away
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
