Kitchen product
SOURCE: Can't open battery case
The middle part slides out. You'll need a small knife or a screwdriver to pry it out gently.
There are openings on two sides. One side has a larger opening than the other. Make sure you pry it out of the lager opening.
Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
Hope that helps!
SOURCE: Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
SOURCE: Salter kitchen Scales Model: 1041SVDR won't turn on.
This sounds very typical of kitchen and postal scales. I know you don't want to hear this, but this basically means it is time to replace your scale with a better scale - perhaps no longer giving Salter your business..
