Tierod ends could very well cause that wobble.
You might have a bent rim on one of the tires or have you checked them. In addition, I would check to be sure a ball joint is not bad and the front sway bar rubbers are not bad where they attach to the A frame of the truck. .
Did you have a front end alignment done? If the tie rods were changed then that could be out. Bad wheel bearing?
Testimonial: "also put in new universal joints in both drive shafts cv axsels in . did not put new tie rods in . Didn't think wheel bearings were bad no wabble when I spin them"
