If the unlatch mechanism on your MotorGuide Xi5 trolling motor is not working, you may be able to resolve the issue by following these steps:
- Check the locking pin: The locking pin on the motor's deployment bracket may be preventing the motor from unlatching. Make sure the pin is in the unlocked position and that there is no debris or damage preventing it from moving freely.
- Check the unlatch lever: The unlatch lever may be stuck or damaged. Try moving the lever back and forth to see if it can be freed up. If the lever is damaged, it may need to be replaced.
- Lubricate the mechanism: If the locking pin and unlatch lever appear to be functioning properly, the mechanism may just be stiff or dirty. Try lubricating the mechanism with a silicone spray or other lubricant.
- Check the wiring: It's possible that the issue could be related to a wiring problem. Check the wiring connections between the motor and the control head to make sure they are secure and free from any corrosion or damage.
If none of these steps resolve the issue, it may be necessary to take the trolling motor to a professional technician for further diagnosis and repair.
