SOURCE: Belkin w/range extenter question
you can use as many as you want, since they just find a signal and amplify it. using more than one shouldnt cause any problems
SOURCE: sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP
1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then
click control panel. Double-click Network and Dial-up Connections icon, double
click Local Area Connection, and Local Area Connection Properties window will
appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’
2. Select ‘Use the following IP address’, then input the following settings in respective
field:
IP address: 192.168.0.2
Subnet Mask: 255.255.255.0
Click ‘OK’ when finish.
Vista
1. Click the ‘Start’ button (it should be located at lower-left corner of your computer),
then click control panel. Click View Network Status and Tasks, then click Manage
Network Connections. Right-click Local Area Network, then select ‘Properties’.
The Local Area Connection Properties window will appear, select ‘Internet
Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’
field:
Next step for both
All functions and settings of this access point must be configured via the web
management interface. Please start your web browser, and input ‘192.168.0.234’ in the
address bar, and press the ‘Enter’ key. The following dialog should be shown:
Please input user name and password in the field respectively. The default user name is
‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web
management interface of this access point:
NOTE: If you can’t see the web management interface, and you’re being
prompted to input user name and password again, it means you didn’t
input username and password correctly. Please retype user name and
password again.
After you connected to the access point by web browser, the first thing you see is ‘Status
and Information’ page. All system and network related information of this access point
will be displayed here. The information is very helpful when you want to know the
detailed information of your access point, and when you try to fix the communication
problem between this access point and other wired / wireless computer / devices.
You can click ‘Home’ on the left,
This access point can be operated in different modes; you can click ‘Basic Setting’ to
select an operating mode you want to meet for different needs:
You can click ‘Mode’ dropdown menu to select operating mode, and there are 3
operating modes available:
AP Access point mode, allows wireless clients to connect to
access point and exchange data with the devices connected
to the wired network.
Station-
Infrastructure
Enable the Ethernet device such us TV and Game player
connected to the access point to a wireless client.
Universal
Repeater
This product can act as a wireless range extender that will
help you to extend the networking wirelessly. The access
point can act as Station and AP at the same time. It can use
Station function to connect to a Root AP and use AP function
to service all wireless clients within its coverage.
You can hopefully figure it out from there.
Testimonial: "tanks v. much for answer, i'll try it right away"
SOURCE: can I use Belkin 802.11g Wireless G Range Extender with virgin broadband?
This is a highly technical question. The technician that installs your fios can help you with an answer. If i'm not mistaken your new fios will come with a special router designed to change the data your recieving to acceptable format and communicate with your other devices. As I stated the tech who installs your fios can further instruct you as to the exact configuration. Hope this helps.
