It will be fine for a minute or two but then one side of the tv screen will like shake or roll you can see some of the the picture but it just dont stay still
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ( in your case )...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further.
If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result?
Hope this helps.
