Ovens have a thermostat. and it might be bad.
You might need to replace it.
Oven Overheating How to replace an oven thermostat
How to replace an oven thermostat in an electric cooker
How to replace the oven thermostat in Diplomat cooker
There is more about how to repace a Thermostat
Be careful. 22oV KILLS
SOURCE: Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
SOURCE: Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
SOURCE: whirlpool oven heating element
what are the meanings of gas marks,what is suitable for making pizza
SOURCE: We've a Whirlpool Gold Accubake System (electric).
its not uncommon to have this happen. it may have overheated . causing the hi limit on the back of oven to fail, that is what you need to ck . and repl if you find it to be bad. **** .. if your want to ck the element then when the back is off range . you can ck the two elem with a ohm meter . . ****
Hello William - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
