It would seem that undoing the 4 screws on the back would free the back (there are no screws on the side). Looking closer, the wrist bands seem to overlap the back cover but I have no idea how to remove or if that is necessary. The wrist bands seem to have 2 metal pieces on either side of the bands. Any ideas on how to replace the batteries would be appreciated.
Looking at pictures of the watch , you will need to remove one side of the strap by undoing the screws on the side of the strap.
once you have removed one side of the strap unscrew the four screws on the case back of the watch.
then you will be able to lift the case back of the watch , it has a rubber seal on it which you need to carefull not to break.
Good luck and be carefull.
SOURCE: Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
SOURCE: How do I change the battery in my Timex Iron Man
You will need to remove the wrist first before the cover will come out.Else pull the wrist out and allow it to leave a gap and then you can move the cover out.
