I have adjusted all my SB800 screens the same and one is still dimmer than the others is this a fault . the SB800 works perfect apart from that.. Thank you
When they are new, the LCD screens should be the same. As LCDs age, they can deteriorate and get dimmer. That is normal. As long as everything is functional, I would not worry. When it goes completely, which may be sooner or later, you can have it repaired.
The other possibility is that the LCD is not at fault. If that is the case, the problem could be in the voltage regulator circuit that controls brightness.
