Boating Logo
P
Pauli Poulsen Posted on Sep 23, 2015
It is a MF/HF transmitter JRC 196GM, when I pressed on TX Tune on the sender it says on display No ATU
I have check connection between Display and Antenna unit and it is ok. But it says No ATU on the display??
JRC World Marine Transceiver. The transmitter did not work we checked handset found ok, we checked antenna found ok.
If the handset and antenna have been checked and found to be functioning properly, there may be an issue with the transmitter itself. It could be a problem with the wiring or circuitry, or possibly a malfunctioning component. It would be best to have the JRC World Marine Transceiver inspected and repaired by a qualified technician or the manufacturer.
Nov 12, 2022 • JRC GPS
SS 5010 not sensing outside temperature. I replaced the batteries in the transmitter and pressed the TX. However, the display inside just keeps blinking. I can see the inside temperature.
Inside temp is separate from outside...no connection whatsoever. If the outside transmitter has new power and fails, it may have gotten wet inside and may be rendered useless. Replace with a new outdoor transmitter.
How do i reprogram MMSI numbers into JRC JSB-196
This is a nice piece of gear, but I am afraid you are going to need the help of a service department that can service JRC gear. I believe you are going to need a hard disk with info. It should have come with radio.
857d does not display tunr icon when set up for atu operation
In the extended menu, double check the "tuner mode". Sometimes the 857 requires a "factory reset" (also in the extended menus) to get it working with external antenna tuners.
3helpful
2answers
Furuno at 1500 atu
This works for the Furuno 1501-Make sure your connections are the same:#1 provide 15V & gnd to tuner(12V works) #2 connect coax between tuner & Xmtr / antenna to tuner #3 set radio to transmit CW carrier @ no more than 10W #4 momentarily short tune to gnd, this will initiate tune process. Watch SWR meter/ listen for tuner to complete, stop 10W carrier & return radio to normal status. I use mine remotely mounted with a 3 wire control cord & a box with a push button momentary switch back at the radio. Connections are 12V & gnd from the power supply to tuner, tune back to control box where the button shorts it to ground to tune.
Troubleshooting a JRC 1000 marine radar unit
Hi does any one have a scanner for a jrc1000 they would sell me please can not find one for sale anywhere.
Very low TX output power on ALL HF BANDS ONLY. Other bands OK!
look for a broken or cracked board near the driver s & finals, try pushing around on the board with your plastic screwdriver, you may luck into it.
5helpful
Tx image set not to display
getfile.asp?rid=1258 September 11, 2008
getfile.asp?rid=3215 Product : imagePRESS C1, All Fax Capable imageRUNNER Models Title : Setting the TX Terminal ID print options Question :
What are the options to print the TX Terminal ID on received pages?
Answer :
The TX Terminal ID settings enables you to specify whether the sender information is printed at the top of every document that you send via i-fax. Information such as your i-fax address is printed, enabling the recipient to know who sent the document.
Note: If you set TX Terminal ID to 'On' you can also set the position of the Terminal ID information which is printed on the recipient's paper.
The default settings are:
TX Terminal ID: On
Printing Position: Outside
Display Destination Name: On
1) Press Additional Functions
2) Communications Settings
3) TX Settings under Common Settings.
4) Press the up or down arrow keys until you see TX Terminal ID
5) Select On or Off
If you select ON:
Select the printing position of the Terminal ID information, select 'On' or 'Off' for display Destination name, press OK.
Printing Position:
Inside: The Terminal ID information is printed inside the image area on the recipient's paper.
Outside: The Terminal ID information is printed outside the image area on the recipient's paper.
On: The destination's name registered in the Address Book is displayed in the Terminal ID information.
Off: The destination's name registered in the Address Book is not displayed in the Terminal ID information.
If you select OFF
Press OK
6) Press Done repeatedly until the Send Basic features screen appears.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Low TX PWR/ATU won`t tune. No SWR and ALC metwr reading?
You've replaced the pre driver, the drivers and finals. Set bias and still low output. The pre driver is the same transistor used as the tx exciter transistor on other pcb chassis on bottom of radio. Follow the gray coaxial wire from the pre driver on the RF circuit board back to the tx/rx i.f. Circuit board. The gray coax cable plugs right next to the tx exciter transistor on this pcb. Again it's on a different pcb all together and on the bottom of the radio and also. Replace it! And check for open bias or emitter to ground chip resistor next to it. You will get your drive back. Very few rigs have I seen the actual Finals blown in the mosfet or the bipolar version. Just the driver stage with a week pre driver and the SMT "pre" pre driver on the same RF pcb. And the tx exciter on the other pcb.
Top JRC Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a JRC Boating Expert? Answer questions, earn points and help others
